i have the same problem the chuck started grinding and one of the three fingers that hold the bit fell out and i need to replace it but cant get the chuck off i pulled the screw in the middle but icant get it offi have the same problem the chuck started grinding and one of the three fingers that hold the bit fell out and i need to replace it but cant get the chuck off i pulled the screw in the middle but icant get it off
Is the screw in the middle of the chuck right or left handed threads and what does the jig do.Is the screw in the middle of the chuck right or left handed threads and what does the jig do.
i have 2 dewalt drill. older one i can see a screw, but it break the bit off. and i can't even take the leftover piese out of the drill. the newer drill i don't see screw at all. i been scratch my head of . pls help!!!!! i have 2 dewalt drill. older one i can see a screw, but it break the bit off. and i can't even take the leftover piese out of the drill. the newer drill i don't see screw at all. i been scratch my head of . pls help!!!!!
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
Thank you for using FixYa. To change the chuck on your cordless drill, open the old chuck jaws to the maximum. Inside the chuck where it attatches to the drill body, there is a Philips headed bolt. Unscrew the bolt in a CLOCKWISE direction. Reverse this procedure to fit the new chuck.
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
i cant say 100% sure for that drill but im betting its not.
it probably has red loctite on it which is very tough to break free. put some heat to it. then it will come easily
It seems it has seized from rust or corrosion. Try using some penetrating oil or just get a new chuck. Mine did the same thing and I just replaced the chuck altogether.
remove the chuck retaining screw, shift the tool into the low position and the clutch into the drill only position. Find a bent handle allen wrench about the size of the chuck (bigger the better) insert short end into chuck and tighten. Put the chuck on a work bench with the long end of handle at about a 30 deg angle and hit it with a hammer. It might take a couple times but it will come off. Let me know if you need any more help, and if I have helped you would you please rate my answer accordingly
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
is there a work around for removing the chuck if you dont have the jig?
can the chuck on a Ryobi D650 Impact drill be replaced
how to replace the chuck on a Ryobi D650 drilling machine
