Question about Toshiba Satellite Pro 6100 Notebook
WLAN is not working
It was working - driver for WLAN is ok. It shows an icon on the right bottom of the screen.
When I refresh network list it says "No wireless network were found in the range". I know there are lots of wireless network in the range ..
Can you please help in resolving this issues
  • Anonymous Jan 16, 2009
    Usually means the wireless lan adapter is not switched on and has to be done so with the Fn + F8 key, unfotunately as I've just reformatted my 6100 I dont have the driver for the keyboard so I cant use the Fn keys. Trying to get drivers for parts of 6100 is soooo frustrating.
  • godsmacker_8 Mar 27, 2009
    My Fn and Function keys don't seem to work. I know the pc was formatted by previous owner, but I cannot find the drivers to make the keyboard work properly now. Does anyone know where I can find these drivers??
  • 667 Answers
Hi masif - please don't rate this yet! Unplug your modem and router. After 60 seconds plug in your modem. After the modem lights return to normal, plug in your router. Give it 15 seconds and then try it. Let me know what happens.
Jeff
Posted on May 23, 2008
My friend gave me a windows embedded ce 6.0 netbook, how do I log in onto my wifi?
Select Connections from the tabs across the bottom. Select WiFi. Find your own wifi from the list of available networks (SSIDs) and select and hold it. Then select Connect. In the next screen, make sure The Internet is selected and click Next. On the Configure Network Authentication screen, make sure Authentication is set to Open and Data Encryption is Disabled and click Next. On the next screen, click Finish. This will bring you back to the Configure Wireless Networks screen. Wait a few moments while your phone connects. Once complete, the status will display as Connected. Click ok from the top right section of the screen then close the Settings window with the x in the top-right section of the screen. Once you've joined a WiFi network manually, your smartphone automatically joins it whenever the network is in range. If more than one previously used network is in range, your pc joins the one last used.
Sep 28, 2014 | Computers & Internet
Meep help
You could try these:
* Check if it is signal related, go near your wireless router and see if the wireless icon shows up without any problems.
* remove the remembered wlan saved in your pc, follow the instructions in the link below:
http://kb.mit.edu/confluence/display/istcontrib/Windows+Vista+or+7+-+Remove+Remembered+Wireless+Networks
Dec 18, 2013 | Computers & Internet
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
I have an acer aspireone notebook and i was wondering if im able to connect to wifi. i have a wireless internet finder that i can plug into it but it doesnt have a cd rom to be able to download the...
All netbooks have both the wired and wireless networking capability built-in. The Acer Aspire One AOA 150 Model No. ZG5 (8.9" screen) netbook has a RJ-45 jack on its left side for wired 10/100 Ethernet. On right-most part of its front is a slide switch to toggle enabling/disabling of the built-in 802.11b/g WLAN for wireless connectivity to WiFi. Click on the following link for a detailed description... http://en.wikipedia.org/wiki/Aspire_one
Pushing the wireless slide switch to the right momentarily will cause either Wireless LAN Enabled or Wireless LAN Disabled in large green letters to appear momentarily at the bottom middle of the screen. Once enabled, look at the Taskbar at the bottom right of the desktop and click on the little terminal icon with ))) and a little red x beside it. This opens the Wireless Network Connection window and you would then do the following...
1. in Network Task sidebar click on the Refresh network list to update the wireless networks
2. in Choose a wireless network on the right side, click on an item in the list to select & hi-light it
3. click on the Connect button to get a pop-up window for Network key & Confirm network key
4. if unsecured network, the pop-up reminds you of the risks but you can Connect Anyway
5. in the pop-ups, you can click to either Connect (for secured), Connect Anyway, or Cancel
6. when connecting, another pop-up window appears with Waiting for the network
7. once connected, the selected network will move to the top of the network list
8. in the desktop's Taskbar, the little terminal icon with ))) will no longer have the little red x
9. right click on the icon to get a pop-up for the status and wireless connection management
Apr 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi can anyone help please, my acer 5050 wireless is not working, just installed windows
1. locate the Wireless communication switch/indicator at the front of 5050 just left of headphone jack.
2. slide switch momentarily to the right.
3. you should see "Wireless LAN Enabled" in green letters at the bottom of the screen
4. a little screen icon should appear in the Taskbar at the bottom right of the screen
5. if it has a little red x beside it, right click on it for more options.
6. if it has no red x, you were automatically connected to a wireless that is open (no security enabled)
7. with the red x and after the right click, in the pop-up, click on View Available Wireless Networks
8. in the Wireless Network Connections window, if no list then click on Refresh network list
9. click on the SSID name for your wireless router to Chose a wireless network
10. click the Connect button to connect to the high-lighted network
11. if your wireless router has security (WEP or WPA) enabled, a pop-up will ask for the network key
12. enter Network key and repeat entry in next line to Confirm network key and click Connect button
13. the little screen icon should no longer have a red x beside it
14. hovering the mouse cursor over the icon will get a pop-up with wireless connection status
Feb 20, 2011 | Acer Aspire 5050-3242 Notebook
I have a wireless connection but cannot open the browser. Another computer (laptop) is connecting fine on the same wireless.
If the Wireless Network Connection icon is at the bottom right of your Taskbar and has a red x, then right-click on the icon to bring up a pop-up window and in that window, left-click on View Available Wireless Networks. This will open a Wireless Network Connection window which will allow you to Choose a wireless network. If the window has the message "No wireless networks were found in range", then you will need to slide the spring-loaded switch at the right-front the netbook to the right momentarily and the message "Wireless LAN Enabled" should show in large green letters at the bottom of the screen. Then in the Wireless Network Connection window, left-click on "Refresh network list" item under Network Tasks. In about 10 seconds, a list of the wireless networks will be displayed which should include the name of your wireless access point (wireless router). Left-clicking on that list item will high-light it in blue. Now click on the connect button at the bottom-right of the window. If the list item has a lock symbol, a Wireless Network Connection pop-up will now show to ask you to "Type the key" otherwise for an unsecured or open access point, a connection should automatically occur without having to type any key. The Wireless Network Connection icon in the Taskbar should no longer have the red x and hovering the mouse cursor over it will show the Wireless Network Connection status. Hopefully, if this procedure has solved your problem, you should consider securing your access point to prevent unauthorized access of it. After securing, you will need to refresh the network list and then do a re-connect.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Dell wireless wlan card stopped working and was closed
go to start menu
click on run type services.msc
scroll down list an double click on let windows zero configuration and click on start and select start up type to be automatic. click ok
then go to start menu
click on run
type devmgmt.msc
go to network adapter and click on the plus sign
right click wireless and select enable
go to the bottom right hand side of screen and right click on wireless icon and right click on view available wireless networks
on the botttom left hand side of that window you will see change advance settings click on it
select the wireless connection tab and make sure that the first box is check that states
Let windows manage wireless networks.
click ok
go back to wireless icon on the bottom rightside of screen and right click and select view available wireless networks and see if you can see your network
Jan 06, 2010 | Dell Inspiron 6400 Notebook
No wireless connection on acer one notebook
1. Try unplugging the wireless router for 30 seconds and plugging it back in.
or
2. If that does not resolve the issue go to My Network Places, Right Click, Properties ... on the icon that represents the wireless connection, right click, select Disable, once the device is disabled, right click again and Enable.
The second set of instructions are assuming you have Windows XP
Apr 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Wlan disabled
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
How to setup wireless on acer n50 pocket pc
i need help to connect via the wlan wireless connection plese help thanks
Feb 21, 2008 | Acer n50 Pocket PC
Toshiba Satellite Pro 6100 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
