Question about GE Kitchen Ranges
Bought a GE counter top range to replace an old GE counter top. New range has three wires: black, red, and bare copper. House wires are black, black (both read 110v live each) and a bare aluminum. Not sure which goes where.
  • jaydoc1 May 22, 2008
    Seems to work.  No fire yet.  Thank you.
    President:
  • 1,314 Answers
Blk to blk blk to red and copper to aluminum
Posted on May 22, 2008
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Oven says: ''supply open neutral'' no buttons work what to do?
That means the range is not connected properly, or the power supply to it is not correct. The range needs the neutral (along with one of the hot leads) to supply the 120 volt portion of the voltage required to operate the control. On built in ovens, the red and black are connected to the two hot supply wires, the white to neutral, and the green or bare copper wire to ground. If your supply only has three incomming wires (older homes) then the green (or bare copper wire) and white are both connected to the neutral.
Nov 11, 2009 | GE Profile JT980 Electric Double Oven
We had a drop in stove and we replaced it with a new slide in but when we took out the old stove it was hard wired in. Soi cut the wires, there were threea black, white and a soild copper so i installed a...
Oh my! The white and black are normally both HOT wires!!! Bare copper is ALWAYS a ground wire, and also can work as neutral. Neutral is the middle prong on the plug.
Turn off the breaker before even touching your appliance, there might be 110v on the metal parts!!!
Black and white should be on the sides, and bare copper - in the middle.
Before switching the wires make sure that black and white really are the hot wires: there should be 220-240v between them.
Oct 14, 2009 | GE Profile JB968 Electric Kitchen Range
Trying to wire jennair cook top to house wiring. Cook top has red white black and bare copper wires. House wiring has two large black wires and a some sort aluminum loosely braided 8 strand wire coming...
if you have220/240 across the house black wires put red from stove to one black then black to blackaluminum to copper should be the ground turn breakers off after you check the volts across the black and the ground make sure the ground is a ground and you will need to run a white wire back to the breaker box for the neutral then white to white
Aug 04, 2009 | Kitchen Ranges
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
I have a three wire lead out of my junction box (bare wire ground/white/black)and my new GE JTP 30 electric oven has a four wire (extra red). What is the wire configuration needed for reinstalling?
hook from the range the green and white wire to the bare copper wire from the house
hook the black wire from the range to the black wire from the house
hook the red wire from the range to the white wire from the house
Apr 24, 2008 | Kitchen Ranges
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
