Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
How to unlock it to play either NTSC/PAL
madhu22 on May 22, 2008
I want to unlock Sony DVP-NS55P so that i can play both NTSC and PAL formatted DVD's.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Apr 26, 2009
-   I have followed the given process, and what it does not is it loads for a long time, then gives the same message, "cannot play this disc" -   Guest
Oct 14, 2008
-   My Sony DVP-NS55P will not accept a PAL/All Region disc.
I have tried the tray-aging hack with no success. Since I do not have a Region 2 disc to experiment with, I do not know if the hack worked for Region 2, but I do know it still does not work for PAL.
-   Guest
Jul 07, 2008
-   I Have a sony DVD Player DVP NS55P Some disk that i play give the message cannot play, is a way to change the region setup of the player?-   wonder7080
Best Solution
posted on Jul 07, 2008
Very Helpful)
worldvet
Rank: Guru
Rating: 91%, 789 votes
Here is the sequence to unlock your DV Player. Clearly this needs to be done exactly to access the secret menu. So, you may want to copy and paste this info into a word program and then print it.
- Begin -
1. Turn off NS55P, leave TV on.
2. Using the original remote supplied with the NS55P, press these buttons in order: DISPLAY, TOP MENU, CLEAR, POWER.
3. NS55P will turn on, displaying the secret menu on the tv screen.
4. Select 2: Drive Manual Operation, then 4: Tray Aging Mode.
5. The screen then shows two input lines: Input Count and Current Count. Use the code 00030 on the first line. Pressing zero first will take you back to the original menu, so instead of trying to type 0-0-0-3-0, try something like 1-0-0-0-3-0 so the 1 in the front disappears after the last zero is entered.
6. Press ENTER on the remote. Disk tray will then open and close automatically 30 times. Let it do this until it finishes.
7. Repeat steps 4-6, but instead of using 00030 in the Input Count, use 00000. Press ENTER, and the NS55P is now capable of reading Region 2 dvds.
- End -
Please ask any questions using the comment box below.
Regards,
Worldvet
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
After entering the code do i turn my dvd player off? I have tried this and it has not worked yet?
Related Problems
I want to unlock Sony DVP-NS55P so that i can play both NTSC...
I connected my dvd player directly to the back of my tv,...
The screen is in black and white I just changed TV's and my...
how to unlock sony dvp-ns78h cd/dvd player
i have a sony ns55p dvd player I want to purchase a...
Can you Help with these DVD Player problems?
the disc wont load
Solve
the disc wont load it just keeps spining and sometimes wont spin at all without a little nudge with... (More)
Black and white picture, Sound works...
Solve
Have a Sony DVP-NS55P. The sound is fine but picture is black and white (clear, not grainy) Do I... (More)
I cannot increase or decrease the...
Solve
I cannot increase or decrease the volume via remote controller even though it is having + and -... (More)
ntsc regions that this unit plays
Solve
i need to know if this dvd plays a ntsc region 3 dvd
Unlock Sony DVP NS55P for Zone 2
Solve
I need help to play Zone 2 DVDs on Sony DVP NS55P which I believe is Zone 1 in Canada.
Sponsored Links
Describe your DVD & Video problem:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
