Question about Toshiba SD-3990 DVD Player
Toshiba sd-3990 Disc-drawer won't open
Unit always worked fine but now the drawer won't open and it doesn't have that little hole that you poke to open like some cd players have
  • mooseboy Jun 02, 2008
    Had the same problem which just started yesterday after about 18 months of use. One minute, it was fine, then bang, the door won't open. I tried unplugging/restarting the device, but can't get the door to open. I hear a mechanical movement inside every time I press "open", but the door doesn't come out.
  • daniwash60 Jun 20, 2008
    The same exact thing just happened to me. Watched a movie last night. Went to take it out this morning and nothing! ..too bad I have a rental stuck inside now. any suggestions????
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
Posted on Oct 07, 2008
  • 3 more comments
  • timmytablet Jan 26, 2011
    Brilliant! Thanks tonycnn! First time I've fixed anything electrical in my life, thanks to your clear instructions!
  • zeydah Jul 10, 2011
    Time doesn't change a great solution, and tonycn's solution still worked great. I would add one wrinkle. After I did what tonycn suggested and the button opened the drawer a couple of times, I screwed the drawer assembly back in and pressed the OPEN button again. This time the drawer didn't open. So I had to unscrew the assembly again, and moved the sideways bar back and forth a few times and then operated the mechanism a number of times by the OPEN button to assure that whatever had been creating the resistance to the bar operating was fully removed. I then reinstalled the assembly and it worked fine. So I'd suggest working the bar and the drawer several times on the first go-around to avoid having to repeat it again. Thanks tonycn.
  • Domih Jun 22, 2012
    Thanks. It saved me time and $$$. Just add a little bit of Teflon lubricant with a Q-tip on the front that sideways bar as well as to the grooves in the back and I guess it's good for one more thousand open/close.
  • jim6802
    jim6802 Nov 25, 2012
    Thanks, Tonycnn, you saved the day!
  • Michael Miller Jul 20, 2013
    Wiggled....jiggled.....manually moved the "little sideways bar" back and forth several times. It works all on its own now. Super post!
I had this problem too, but I just got my DVD out by pressing OPEN and banging on the top a second later... may be a caveman solution, but it worked!
Posted on Jan 23, 2010
Hello Everyone! Thank you so much for all of the information. I read Tony's solution and was about to try it when I read the caveman solution. I went to my DVD player, turned it on, stopped the load process and hit OPEN and then banged on the top of that section. I had to do this three times and gave it a really good wack on the third try and BINGO!! the drawer opened. I've now retrieved the DVD and tried the open and close function several times and it works like a charm. Love this site!!
Posted on Jul 15, 2012
From what I have found ... and it seems to work all the time is to do the following when your dvd tray will NOT eject ---->
get the controller, and continuously hit the "open" button UNTIL it ejects the dvd tray, for me this is roughly 10 times .... then it will open.
Good luck.... this dvd player is a real POS ... as most of the time the unit won't power on for me, but when it does this works.
Posted on Jul 13, 2008
The code mooseboy refers to is 2005 (press 'Setup', then enter the code). There's no feedback from the machine, but it switches the tray lock on and off. That wasn't the problem in my case - I had to go the disassembly route (thanks TonyCCN!).
Posted on Aug 09, 2009
Actually, I found the solution in the manual. My DVD player had gone into some other Mode, Demo mode or something, which requires only entering a 4-digit PIN found in your user manual. Once I entered this PIN via the remote, the player worked fine again.
I have no idea why it went into this mode, but it's certainly worth testing before chucking your whole player.
Posted on Oct 08, 2008
    Tonycn's suggested fix worked like a charm.
Thanks to TonyCCN, I had the same problem and the multiple opens, and unlocking the tray did not help. I followed TonyCCN's instructions, and it eventually the tray opened.
Posted on May 04, 2009
How much do you charge?
IF you are trying to remove a CD from a player that doesn't open naturally, there is usually a small hole into which a straightened paper clip can be inserted to manually open the "drawer". Don't get carried away with the paper clip, and just a little, single poke should do it into the small hole about the size of the diameter of the wire - not somewhere else.
Nov 24, 2011 | Teac Audio Players & Recorders
My sony dvp-sr200p, disc tray is not opening?
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
Apr 11, 2011 | Sony DVP-SR200P DVD Player
Player will not read discs. keeps saying "no disc" when discs are inserted. Worked fine until today.
Easy option first , clean laser with a laser cleaning disc ,if that doesn't work then (I assume you have tried more than 1 disc). a laser won't read a dirty disc, you may have a laser mechanism fault ie laser sticking in its tracks. you could try oiling the cradle that the laser sits on. other than that it is a costly repair.
pete
Mar 06, 2011 | Toshiba SD-3990 DVD Player
Screen on TV shows Toshiba label and says there is no disc but a disc loaded in it
The laser unit has gone bad. Usually it's not worth replacing as it is about 3/4 the cost of a new player.
Jul 25, 2009 | Toshiba SD-3990 DVD Player
CD is hung up in the player and does not come out with the tray
There are a few solutions:
1. hit it ok just kidding
make sure when you are trying to open it does not say "disc Lock" or some sort. You can solve this problem by hitting the device menu and typing in 2005
2. Open up the device by unscrewing the six case bolts and then the 4 dvd section screws. After this I had the problem where my dvd was stuck in the play mode so the tools would just not let go. I had to gently wiggle them apart however be very careful. I have also heard that it might be a tired arm on the side that just needs some coaxing. HOpe this helps
Mar 23, 2009 | Toshiba SD-3990 DVD Player
Get Disc Error on display when loading a disk
you have problem with EPEROM IC you have to bring your set to toshiba repair center and they give a new program to your set . the program of your set is defected must be repaied
Mar 13, 2009 | Toshiba SD-3990 DVD Player
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
MP3 files on a DVD+RW disc - not all display or play
Toshiba SD-3990 does not recognize DVD+R/RW discs. You need DVD-R/RW
Jan 09, 2008 | Toshiba SD-3990 DVD Player
Dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Sep 16, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba SD-3990 DVD Player Logo
4,101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
