Question about Brother MFC 9700 All-In-One Laser Printer
How to photocopy?
I do not know how to use the machine to photocopy doublesided paper.
  • Cora08 May 22, 2008
    Thank you and hoping to get solution to my problem.....
Unfortunately, the Brother 9700 is not a "duplex" printer, meaning is does not print/scan/copy both sides of the paper. There is no way to solve this problem, other than to buy a new, duplex printer. Sorry!
Posted on Jul 03, 2008
I have a canon ir 1018j black and white photocopier that does not pick a paper nor photocopy
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
Sep 05, 2016 | Canon IR1018J Black and White Copier
Problems picking up paper
You should get it checked by an Authorized Service Professional. If this doesn't do, check if your paper is of a compatible weight (GSM) Check your Machine for compatible paper specification and to know this you may read user manual or your machine. Then check your Paper Packet. If your paper is of a compatible weight, you should call authorized service engineer of your machine. If you find you were trying with a non-compatible type of paper, change to a compatible paper and if it still jams, something wrong with your machine is definite. Contact Authorized Service engineer in such a case.
Apr 24, 2014 | Ricoh Aficio Mp 2000 Copy Machine
How to remove jam paper from photocopy machine
Hi there remove the front cover & side cover there you can find the jam papers. Just pull the paper & start printing. After that if you face same problem then check the paper trey & then turn off the machine for 5 minute & try. after that let me know the result.
Jan 18, 2011 | Canon imageCLASS D660 All-In-One Laser...
My photocopier sharp z810 is not accepting paper.how do i rectify the fault or problem.i need a solution please.
if there is paper in the paper tray but the machine still says no paper, then the paper end sensor is broken in the tray. take the paper tray out and you will be able to see a sensor on top. when the tray is fitted the sensor is on top of the paper. the paper lifts the sensor to activate. i am a photocopier technician.
Oct 01, 2010 | Sharp Office Equipment & Supplies
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Brother MFC 9700 All-In-One Laser Printer Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
