Question about GE WHRE5260E Top Load Washer
Water leaking where motor goes into the drum
I have a WHRE5260E GE washer that leaks water at the motor where it goes into the drum. It had a screw missing and we replaced the screw but that did not stop the leak. I have to vacuum out the bottom of washer about every five loads before it overflows to my floor. Is there some sort of seal that needs replace? Any help would be greatly appreciated ASAP. Thanks
Carla
    President:
  • 1,314 Answers
There is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
Posted on May 22, 2008
My GE WHRE5260E leaks out the bottom occasionally ,what is the problem
check the seal on your drain pump it is where it attaches to the motor
Feb 16, 2010 | GE WHRE5260E Top Load Washer
GE Profile washer...model: WPRE6150HOWT sesr:
i'd check the drain pump-there is a seal where it attaches to the motor-leaks often there, also could be a leak in your tub seal between the tub and transmission, also sometimes the outter plastic tub gets a crack in it and leaks
Feb 15, 2010 | Washing Machines
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Model ge wnsr3120w0www
I will tell you for 14.95. Thanks for the info anyway. Send no more emails.
Oct 14, 2008 | GE WHRE5260E Top Load Washer
Caloric Dishwasher DUS203190A
Hi thanks for the question On a ge dishwasher , more often than none it leaks from the motor seals If thats what the problem is you will see it leaking from the motor shaft , It could be leaking from above the motor if it si from the tub ,Replace the part that joins the motor to the tub if its motor seals .Replace motor seals
Sep 07, 2008 | GE WHRE5260E Top Load Washer
GE profile washer
Thanks for the questionOn a ge washer theres a over flow tube located at the back left side Sometimes if you use a high sudzing detergent , it could leak not to much to worry about just change detergent to a low sudzing one THanks for the question The appliance doc
Sep 03, 2008 | GE WHRE5260E Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Water leaking from bottam while in running cycle
water leaking from under the machine while running. Also will not stop filling in the rinse cycle.
Jun 14, 2008 | GE WHRE5260E Top Load Washer
Leaking from the front
take a butter knife and release the two clips on the top of the front panel (look in the seem between the top and front panel and push the butter knife directly into the clips), this will release the front panel from the machine. then you can see where the water is coming from.
May 14, 2008 | GE WHRE5260E Top Load Washer
GE WHRE5260E Top Load Washer Logo
133 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
