Question about Dryers
Changing a dryer belt
Hi I need help to figure out how to change the belt on the fridgidaire heavy duty dryer. Got a new belt but the back of the dryer seems to be welded to the drum.. how do I get the belt around the drum and down to the spinner?
thanks in advance!
    President:
  • 1,314 Answers
Unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .and put yours on
Posted on May 22, 2008
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
My kenmore heavy duty dryer model 96374200 well not spin no more is there a bearing i can replace
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 21, 2011 | Dryers
I have a kenmore washer dryer ( stacked ) heavy duty 2 speed motor . The top dryer is SQEEEEAKING so loud it is making me INSANE . I removed the front of the unit so I could see the drum and belt ... then...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 23, 2011 | Kenmore Dryers
We have a frigidaire gallery, heavy duty, stackable washer dryer. The dryer has stopped spinning. No grinding or anthing just not moving. Belt?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 22, 2010 | Dryers
Dryer will not turn on is there a fuse in an older kenmore heavy duty dryer
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 12, 2010 | Kenmore 500 6952 Dryer
Have power cam hear the clicking noise whrn the start button is pushed. whirlpool heavy duty dryer
heatman101
Nov 09, 2010 | Whirlpool Dryers
Have a Kenmore 70 Series, Heavy Duty Dryer. Push the on button to start, nothing happens.
heatman101
Sep 19, 2010 | Kenmore 700 6972 Dryer
General electric heavy duty automatic dryer won't start after running heavy load
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 19, 2010 | GE Dryers
Dryers Logo
93 people viewed this question
Top Dryers Experts
