Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 I had the garmin plugged into the car and I got a warning of low battery. I replugged the garmin in and it seemed to be working fine. About 15 min later the garmin just quit and I can't seem to get it to work again. How would I recharge it if that's the problem
  • trydionel May 23, 2008
    I have the EXACT same issue with mine. Happened just yesterday. I tried plugging it into my laptop (via USB on a Mac) to charge it up there (thought maybe my car outlet was bad), but my computer hung as soon as I connected it.
  • 4 Answers
Resetting it and recharging it again wsemed to work for me
Posted on May 24, 2008
  • CRE_news May 24, 2008
    Dont charge using the PC. Takes too much power unless you have a powered HUB. I have to disconnect all USB ports to update the software.
I ran the battery dead on my c340 GPS Now
You will have to open up you unit, and replacing the battery, you can get them from Garmin.
May 08, 2010 | Garmin StreetPilot c340 GPS Receiver
C340 will not come on by battery or plugged into car. Could the lithium-ion battery be bad, if so how do I replace?
Try pulling the face off and resetting it,
If it will not reset, work in the car or the house,
The battery need's replacing.
If your savvy (soldering), Ebay for battery,
or Garmin Around $100
http://www8.garmin.com/support/outofwarranty.html
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=67938&whichpage=1
Regards
Jun 19, 2009 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin shuts off after 15 seconds with a low battery indicator
you will have to connect it to a computer using the usb port. thats the only way to charge it once the battery gets real low. my unit did the same thing.
Apr 11, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Not charging
If it won't turn on even when plugged into your car then it probably is the car adapter. Check the fuse. It is located in the tip of car adapter which can unscrew.
Dec 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Sep 08, 2007 | Garmin StreetPilot c340 GPS Receiver
C340
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
