Question about Tomtom GO 920 GPS Receiver
TomTom920T is locked ON and wont respond to power button
Happened after a voice install..
  • thebucklands Jun 28, 2008
    the screen logo is displayed does not do anything just stays in display mode model tom tom go 910
  • Anonymous Jul 30, 2008
    tom tom i have to hit the reset button to turn it off when putting back on the screen remains the same with just a picture of me on it
My TomTom go920 has problem with the power button. Battery looks full but it has a hard time to power on....I will return it next week!
Posted on Jun 23, 2008
  • 515 Answers
First thing to do, reset:
http://www.tomtom.com/support/index.php?Language=1&query=reset&FID=6965
Try power on after reset, hold power on for several seconds.
If Red Cross issue after reset:
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Posted on May 30, 2008
Have an LG Bluetooth headphone set that voice activation of calls has stopped working. Must use the iPhone to look up numbers and dial. Not safe. Please help
If you do not have Data, SIRI will not work, so change your phone to 'Voice Control.
  1. Go to Settings > General > Accessibility > Home Button.
  2. Under Press and Hold to Speak, select one of these options: Siri: Siri will respond when you press and hold the Home button. Voice Control: Classic Voice Control will respond when you press and hold the Home button. This will also turn off Siri.
Oct 28, 2017 | LG Cell Phones
Mic is synced but cant use online
my problem is the mic wont syncronize and wont respond to my voice and i cant hear other people through it .it still flashes blue and charges fine
Aug 30, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
My iphone wont respond to my touch in the bottem halk
Have you tried doing a hard shut down? Hold the silver button down on the upper right corner and also the home button (center,bottom indented button) together for about 10 seconds. the phone will completly shut off. then wait about 10 seconds and hold down the upper right hand button until the apple appears on the phone then release the button and wait (20-30seconds) . Doing this usually solves all my issues with my iphone when it gets locked up like this.
Jul 01, 2009 | Apple iPhone 3G Black Smartphone
Asus k8v-vm wont resume from standby.
get into the bios and change the setting to start from any key save yes and ok -esc
Jul 04, 2017 | ASUS K8V-VM Motherboard
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Jensen vm9410 wont power up
easiest thing first. check the fuse on the hot wire on the radio harness. next, check to ensure the hot wire is to battery power, and the acc (likely yellow or orange) is attached to a wire that turns on with the ignition. next, check to ensure good ground. all this should take less than 10 minutes.
Apr 06, 2008 | Jensen VM9410 Car DVD Player
No response
RTFM You need to press the play button to turn the unit on. Then the menu button works as advertised.
Nov 10, 2007 | RCA RP5020 Digital Voice Recorder
Tomtom GO 920 GPS Receiver Logo
235 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
