Question about E-Machines eMachines Desktop PC
T3256 The problem that I'm having is, when I turn on my computer, it starts to boot up, then I hear a click & my monitor goes blank & displays a "no signal" message. The power is still on in the tower, but nothing else. Do I need a new motherboard, processor, or what? Thank You for your time, Gena
  • Tolegirl May 23, 2008
    I bought a new power supply & installed it. Unfortunately, it didn't fix the problem. The monitor still went blank within a few seconds of turning it on. If you can think of anything else that might help, let me know. Thanks for your time, Tolegirl
  • shaker t May 23, 2008
    I have exactly the same problem. Tried with another monitor - no luck.
    Mine sometime crashes straight after the big e display, other times after selecting safe mode etc. Sometimes it even gets to the windows xp startup screen and either goes black"no signal" or just freezes.
    Guru:
  • 1,342 Answers
Sounds like you may need a new power supply for your computer.
Here's a link for reference
If you are not comfortable taking your pc apart you should take it to a repair shop.
Posted on May 22, 2008
  • Georgia B
    Georgia B May 23, 2008
    Have you tried a different monitor?
That sounds like a software problem like a virus or a damaged driver or bios. if any hardware is to blame it would be your video card(the peice that you plug your monitor into) if this is sodered directly into your motherboard take it to a repar shop or if your feeling abitious replace it yourself. it shouldnt cost anymore than 50 dollars for the repair. 100 if the video card is removable(but on the upside that means that your getting something 3times or more powerful than the one your computer origonally came with and will maximize your capibility).
Posted on Jul 01, 2008
Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
Hallo there
I hope you have got your screen beack, if not try to restart your computer in safe mode.
The restarting can be done in the following way:
1. Click START, click TURN OFF COMPUTER, and then click RESTART
2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
Now to the display settings
1 Open Display Properties in Control Panel
2 Click the Settings tab
3 If for some reason you are not in safe mode go through following:
In Colour quality, clock to alower settiing
Move Screen Resolution slider to the left if you want to reducethe size of the desktop
To Refresh frequency click Advanced and check the Adapter and Monitor.
4 After you have made your changes click OK
restart the computer if you are told to do so. But do not do it in safe mode..
Good luck
Kobrun
Feb 29, 2012 | Dell Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
I have this monitor and just bought a new computer. When the computer boots up and gets past the "windows" graphic monitor goes black. It worked fine with my old computer and my new computer works with an...
You may try the following steps:
Boot the computer in safe mode.
While booting press the F8 key and on the Windows Advance boot screen, select safe mode and press enter.
Once you are on the logon screen, select Administrator account.
Click on Start and rightl click on My computer, then click properties
Go to hardware tab and click on Device manager.
In the device manager look for Display adapter, Click on the + sign, right click on the listed devices and uninstall.
Now you should be able to boot the computer in normal mode.
Please let me know if you need any further assistance.
If you find this solution helpful, please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
Nov 27, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
When i turn on computer screen is blank and the hard drive light is a solid amber for a minute then nothing....bad video card? Does same on two different monitors.
Video is on-board the motherboard on this model BUT you can buy (or borrow) a video card pretty cheap. When the computer starts up, do you hear any 'beeps', etc.? Might be something other than the video card...
Nov 21, 2009 | E-Machines T3256 PC Desktop
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
E-Machines eMachines Desktop PC Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
