Question about Motorola Mobility MD4260-2 Twin Cordless Phone
You seem to know this stuff
I have a flashing number 1 it looks like I have a message but I don't. Any suggestion?
  • Anonymous Aug 29, 2008
    Thanks for the solution! It takes a few times to get it right but keep on trying...it works!
    New Friend:
  • 18 Answers
See the solution here.
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
Posted on Aug 01, 2008
Why doesn't the message waiting light flash when there is a message?
I assume you have pap2t admin password....
login to admin
click on Line 1 tab.
change "VMWI Serv:" to yes.
save
click on advance view.
click on USER 1 tab
goto bottom.
With vmwi being on, you will get a periodic ring splash to let you know you have VM. You can adjust it here. I have mine set to 0.2 seconds as I like getting a whole house ring to let me know there is new VM, so I don't have to remember to look at the phone/light. Some set this to 0.0 seconds in order to get rid of the ring splash. I also set "Ring On No New VM:" to yes because I have an old caller-id box that needs a ring splash AFTER retrieving VM in order to clear its message waiting light. Newer stuff generally doesn't need this.
save.
You would need to turn off provisioning or your changes will go back to provisioned settings every hour. After you are sure you like the new settings, you can send a ticket to get the settings changed in the provisioned file at VT.
Sep 12, 2014 | Lands Phones
ViewSonic LCD monitor displays "No Signal Digital" message
There is something wrong with the main logic board. The firmware thinks that there is a DVI connector installed. Such problems with other devices are fixed by reflashing the firmware. But I don't see any connector on the board for that purpose.The faulty flash memory chip is marked with "A", meaning there is flashed the "A" firmwre version of all possible versions - probably this with only VGA connector. My suggestions are: try to find similar working logic board. I didn't find any on ebay, but you may find somewhere else. The other option is hard one - to try installing DVI connector on this board. Unfortunatelly we don't know the parameters of the parts needed. There have to be several diods, some capacitors and a transistor, all SMD. There is also a missing 8-legged IC probably connected somehow with the DVI. :(
Just for case carefully inspect the cpu legs for bad solder.
Apr 07, 2012 | ViewSonic Graphic VG2021m LCD Monitor
I have to fd2560 , 5.6 color monitors like brand new, just don't have the wires ! Any suggestions on how to get a pair???
I am also looking for Necvox solutions for a BMW i have just bought. You could try the following London firm - www.mrx-24-7.co.uk who seem to supply Necvox stuff. good luck.
Mar 13, 2012 | Car Audio & Video
Need to replace flash
The flash is not consumer-replaceable. You will need to have it serviced and it will be very expensive.
Oct 23, 2011 | Olympus Camedia C-4000 Zoom Digital Camera
Give the code to flash my 2690 nokia
Are you looking for unlocking?
Don't use flash it damage your mobile ...I suggest you to use unlock code is best way to unlock your mobile...If you need you can try it here theunlockarena.com When you receive unlock codes for your phone, they will look like some symbols followed by a long number and then some more symbols.
There is only one unlock code for most handsets as soon as you get the "phone unlocked" message and then use a SIM from another network in the handset....
You can only have five failed attempts before your phone removes the option of being unlocked...If you see a "code error" message and you are 100% sure that you entered the code correctly.... you need to specify the network provider....
Jun 10, 2011 | Computers & Internet
Hi i am looking for the part number for a fly back transformer kp-61hs30
Sony part number 1-453-285-21. It's not difficult to find these online. I suggest getting an original Sony part. Many of the cheap aftermarket replacements I've tried in Sony sets don't seem to work well. You'll pay a little more but the part will work. I just found this listing on eBay for one, and it's a good price.
Good luck with the repair!
May 04, 2011 | Sony KP-61HS30 TV
I'm running windows 7 on a Toshiba L455 and I keep getting a prompt that says; can not find "flash.ocx"
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
  • You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
    1. Download the Flash Player uninstallrom Macromedia. Save it somewhere convenient.
    2. Run the downloaded program and allow it to finish.
    3. Once the uninstall completes, restart your computer.
    4. Visit the Flash Player website and download/install the latest Flash Player version.
    5. That's it!
  • You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
    2. Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to "Flash.ocx".
    4. If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
if the problem still persist please let me know.
Apr 15, 2011 | Computers & Internet
Need help don,t know what my rca mp3 play number is to get a manu
YOU CAN EITHER DELEATE IT BY 2 WAYS:
1. GO ON UR MP3 PLAYER AND ON THE SONG, PRESS THE MIDDLE BUTTON AND SCROLL DOWN TO WHERE IT SAYS DELEATE OR U CAN PLUG IT N 2 THA COMPUTER AND RIGHT CLICK THE SONG AND CLICK DELETE
Feb 27, 2009 | RCA M4204 MP3 Player
8310 blackberry curve
To answer your first question, the green flashing light is the coverage indicator. It will flash green when you have a wireless signal. If you want to disable that then go to Options > Screen/Keyboard and then set the LED Coverage Indicator option to Off.
Sep 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Flash is not working ??????????????
This camera has four flash modes and each time you press the button the mode changes. As you press the button you should see the indictor in the upper left side of the screen.
1. In automatic flash, the camera will decide if you need flash or not. This mode does not have any indicator on the screen
2. Forced flash, this will cause the flash to be constantly on. The indicator looks (kind of) like a lightning bolt.
3. Slow Syncro, this mode slightly delays the flash and is used to lighten up the background more the foreground. The indicator looks like the lightning bolt with SL next to it.
4. No flash, this will turn off the flash. The indicator looks like a lightning bolt enclosed by a circle with a diagonal line through the lightning bolt. (similar to a no parking sign).
If you don’t see the indictor changing on the screen the switch behind the button is malfunctioning.
Nov 26, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Motorola Mobility MD4260-2 Twin Cordless Phone Logo
188 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
