Question about Pc America Restaurant Pro Express
Scrolling The screen appears to large for the monitor and will not let us scroll over to other buttons and options.  Help what do we do?
  • phredphlint May 11, 2010
    RPE requires a 1024x768 minimum resolution and a 96 dpi setting (not 120)
    Problem Solver:
  • 7 Answers
YOu would require proper driver for your screen to have a proper display.
Posted on Oct 15, 2008
I had the same problem and learned my hardware is not compatible with the current RPE. The screen resolution for the software needs to be higher than the monitor might allow. I had a 12" Posiflex and had to scrap it.
Posted on Jul 23, 2008
Neovo f-419 menu keeps scrolling and will not stop
You have dust on the micro switches on the front.You can resolve this by flicking the buttons on the front, or you could take it apart and clean the switches with a spray cleaner like wd40 through them making sure you mop up all the excess.
Jul 13, 2013 | Neovo F-419 19" LCD Monitor
Hi, I have one of these Elite N16354 monitors that tell you how much electricity you are using, The master transmittor is in the power box, and I presume connected to the meters the monitor sits in the...
on the rear of your in house monitor you will have a link button. if you press and hold that for about three seconds a small wireless search icon will appear on the bottom of the screen. it should be scrolling up. if it does not connect check the sender unit in the power box. it should flash a red light every 6/18/36 seconds. press the only button on that unit to scroll through these options. mine does disconnect every now and again and i just press the link button and its back. think the wireless internet may be affecting it :)
hope this helps.
Dec 13, 2010 | Computers & Internet
Scrolling colored lines on the monitor, overlaying the screen.
You either have extremely screwy drivers, a bad cable or your monitor/panel is shot. Replace any of the above to resolve the issue.
May 29, 2009 | Acer X193W LCD Monitor
Track ball does not allow east scrolling; it only allows west, north, or south scrolling
Try to change the horizontal sensitivity and vertical sensitivity of the trackball to 100%,to do this follow the below mentioned steps
1)press menu
2)select option icon
3)scroll down and select screen/keyboard option
4)select horizontal sensitivity and change it to 100%
5) select vertical sensitivity and change to 100%
6) press menu button and select save
May 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
The small scrolling icon on Windows Vista
1-Firstly you go to system control panel(Start button->setting->Control panel)
2-select the mouse option and click
3-you see the 5 option under it,select the pointer options
4-under the visibility option unmark Display pointer trails &
Hide pointer whilt typing option
and also check the pointer speed option under pointer option.
5-than ok..
Thanks,
Feb 10, 2009 | Microsoft Windows Vista Ultimate Edition
Display not centered
there are 6 buttons at the buttom of the monitor.
option 1). press the auto adjust.
option 2). from the right to left: "power","LED","Manu/enter",">"," <" ,"auto adjust"
to adjust the screen:
press manu-button, use <> button to navigate to the 3rd button on the top row.
(4way arrow). press manu again. that is going to get you into the submanu.again use the <> to navigate to H. Postion button.use the <> to mve the screen to the desire postion.
press manu again and select the right button on the button row (exit) and press manu.
Nov 06, 2008 | Envision EN-7220 17" Flat Panel LCD...
Page size
If you have XP see here : Accessibility Tutorials for Windows XP: Choose Screen Resolution
If you have Vista see here : Windows Vista Help: Change screen resolution
If the problem concerns the monitor settings instead, unplug monitor from power for two minutes to reset it.
Oct 15, 2008 | Acer Aspire™ T180 PC Desktop
Acer X193W Monitor / screen image
Check your video card drivers are installed correctly.
If unsure, the reinstall them again, it won't hurt the system and there are probably new drivers out for it anyway.
Apr 12, 2008 | Acer X193W LCD Monitor
Scroll ring intermittent / non functioal
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Nov 20, 2007 | Kensington K64325 Trackball
Computers & Internet Logo
127 people viewed this question
Top Pc America Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Will Halftowaite
sunil dixit
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
