Question about GE Washing Machines
Our washer does not work, no water enters. - GE Washing Machines
    Genius:
  • 1,665 Answers
There's no water at all If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Posted on May 22, 2008
Cold water valve not working
the selinoid has gone bad in ur valve
May 11, 2014 | Amana Washing Machines
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
Washing machine keeps flashing up fh and not working
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Oct 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Purchased model #ghw9150pw1 used, everything seemed correct, placed clothes in washer, closed door selected and so forth. Saw small amount of water go in, then it rotated one way then the other, then it...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Sep 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite quitepak 2 front load washer and the estimated time remaining keeps flashing H F and the machine quits working
Hi
Daniel
Sep 18, 2011 | Kenmore Elite 45986 Front Load Washer
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer only washes on hot
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
    Water will not enter machine
    If you advance the timer past the fill cycle (if possible) does the washer function?
    If so, you either have a bad water solenoid or a kinked hose. If the washer does not work, then probably the timer is bad.
    Sep 06, 2008 | Dishwashers
    Washing Machines Logo
    79 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
