Question about Whirlpool 24 in. DP840D Free-standing Dishwasher
Soap door doesn't open
The soap door doesn't open on my dishwasher, as a result it only gets soap to the dishes during the prewash leaving the dishes not quite clean
    President:
  • 1,314 Answers
Remove the door panel and replace the wax motor on the dispencer
Posted on May 22, 2008
SOURCE:
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
I bought a new bosch dishwasher less than one year ago, and it doesn't clean my dishes because the lid on the soap dispenser will not open during the cleaning cycle. Please help SAP! Thank...
Try cleaning the latch that holds the door. After a year the detergent will build up on the spring causing it not to open. If that doesn't do it call the people who you bought it off of. It should have a extended warranty for a year.
May 14, 2011 | Dishwashers
Dishwasher soap dispenser does not release(sometimes partially)and as a result dishes are not cleaning
the solenoide which pops open the soap lid may be faulty.
Better to poar your dishwashing powder or tablet in the bottom of the dishwasher tray until you get the machine repaired. You may want to do a prewash rinse first, then stop the machine and add your soap.
Make sure not to use too much soap. Just the normal amount as you would use in the soap dispenser.
Ash
Oct 27, 2009 | Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Dishwasher soap not opening
These rely on mechanical timers and springs on the soap dispenser. They get a bit gunked up after a while. Don't prewash and run the the dishwasher for a few cycles with the dispenser open (put the soap tablet in the cutlery basket). If you listen to the machine you may be able to hear the click when the dispenser should open which at least tells you that it should be working
Jun 13, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Dec 28, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't dispense soap
The dispenser's unit should be replaced. You can try as well to operate the dishwasher while putting the powder detergent or the tablet on the dishwasher's bottom and if you will get good results, to opereate the machine this way. Good luck!
Sep 05, 2007 | Roper 24 in. RUD5750DB Built-in Dishwasher
Whirlpool 24 in. DP840D Free-standing Dishwasher Logo
239 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
