Question about Ricoh Aficio 450 Copier
Aficio Ricoh 350e - Warm up error (fuser)
Hello -  Overnight we usally power down and put our printer to sleep with a save energy mode. This morning while powering up the printer came up with an error code of sc542-00. At one point we had a tech come in and diagnose with another problem and he informed that there is a reset code that one can enter to clear out the error code. I'm in hopes that this might reset the issue at hand with the fuser error. Thank you for any ideas you might have.
  • Anonymous Jun 14, 2008
    sc-541
  • 64 Answers
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
Posted on May 24, 2008
How do iremove error of code sc542(ricoh aficio 1515mf)
542 Fusing temperature warm-up error (center)
The fusing temperature rises less than 7 degrees in 2 seconds, and this continues 5 times consecutively. The fusing temperature is not detected in 25 or 35 seconds. • Fusing thermistor defective or out of position • Fusing lamp open • Power supply board defective
This is the reason for the error code according to (printcopy.info) Might help you in some way, but not my area of expertise.
Jan 20, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
Aficio 350e error code sc547_00
fuser unit error ,go to simulation i.e press 107 and press cancel key and hold then switch off machine an on
Aug 11, 2013 | Ricoh Aficio 450 Copier
My Ricoh CL2000n is getting the "SC 554" message and the power saving mode is turned off. Do you have any recommendations?
That is a fuser code and will not go away by turning the power off and on. The code needs to be reset in the service mode, and maybe a new fuser.
Nov 25, 2009 | Ricoh Aficio CL2000N Laser Printer
I need the fuser reset code for the Ricoh Aficio 350
Try to reset with 5801 it means:
enter service mode with 107 and find 5801 and execute then switch on and off the copier.
Please try if it works.
Oct 15, 2009 | Ricoh Aficio 350e Printer
Error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Jun 26, 2009 | Office Equipment & Supplies
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Jun 25, 2009 | Ricoh Aficio 450 Copier
Error code sc545
That's a fuser warm up error. Likely either a blown fuse, lamp or thermistor. Fuser is usually replaced as an assembly, and code can only be reset in "service mode" after the cause is fixed.
Mar 14, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 450 Copier Logo
878 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
