Question about HP Officejet 7210 All-In-One InkJet Printer
Cleaning up the mess of black ink leaking
How do I clean the mess of ink that is pooled in the bottom pad under where the ink cartridges are? i removed the cartridges and moved the carriage to the middle however, the pad will not come all the way out. Even if I do get the pad out how do I clean it and get it back in? Would rather not buy a new printer!
Wasn't sure whether to mark this a solution or sympathy because I have the exact same issue. The sponge is stuck on two plastic tabs that jut out, one in front of the cartridge stopper—a platform that is normally retracted but which extends if you shut the power off—and the other in the back of it. You can see them if you look carefully.
Once you get the sponge out, you can wash it in 97% alcohol or distilled water. Unfortunately, since half of the sponge is under the cartridge stopper platform, you may not be able to get it entirely out of the printer (at least I wasn't able to). Instead, I just soaked up as much ink from the well as I could with alcohol soaked paper towels—a lot of paper towels.
Posted on Jan 01, 2009
    Scholar:
  • 162 Answers
You shouldn't need to clean it. Just squeeze it like you would a sponge using something like a paper towel. This is a messy endeavor, be careful.
Posted on Jul 25, 2008
Epson wf-2530 - cyan is printing out as a pale pink even after inserting a new cartridhe
My suggestion is to pull the cartridges check your ink collector pad. This is where the extra ink gets wiped from the cartridges as it goes by. make sure that the pad is not pooling up check the bottoms of your cartridges and wipe them clean also and do a quick cleaning inside if you see any extra dust, ink etc.. just wipe it clean. then power your printer off and back on again and see if that helps. Hope it does the trick for you.
Nov 08, 2014 | Epson Office Equipment & Supplies
Ink cartridge leaked inside HP photosmart 7350. How do I clean up the mess. I tried cleaning w/Q-Tip and alcohol but there's a lot of ink there. I probably have to clean it all before installing a...
Lots of Q-tips! I'd also use some small pieces of cotton cloth--be careful it doesn't leave strands of cloth in the bottom of the printer. I've had this happen and I just stuck with it until it got reasonably clean.
Oh--and warm water will work just fine. Most of the ink is water-soluble
Oct 26, 2011 | HP PhotoSmart 7350 InkJet Printer
My HP 3210 printer seams to be leaking at the printer head. Just below where the 6 ink lines (6 lines in one wide black strip) enter the carriage. Ink is pooling under the base location of the printer...
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
You could carefully clean this as follows:
put the printer on some newspaper to avoid further spills.
Turn on the printer, then open the lid to allow the carriage to move to the center.
Now unplug the printer, then gently move the carriage to the left and out of the way.
You should now have limited access to the spittoon area.
You can clean this area by carefully scooping out the ***** of ink with a plastic spoon. (Be careful not to drop ink sludge on your printer, desk, carpet or clothing.)
Once most of the ink has been removed then use a crumpled paper towel to soak up the ink in the bottom of the service station.
It may take several rounds of this to clean up the service station.
It is not necessary to completely clean the service station, just get the majority of the ink out.
Once this has been completed you could turn the printer up and clean the bottom area of the printer. Do not tip up the printer before the service station has been cleaned or you are likely to create a mess....
hp printer ink cartridge
Sep 10, 2010 | Office Equipment & Supplies
Lexmark 1240 black ink prints in streaks.
Take the cartridges out, then unplug the machine so the cartridge holder stays in the middle. Take a bunch of wet q-tips and clean all around where the ink would come out. Check rollers and anywhere the ink could have dripped. Double check the maint. station, sometimes there is a wiper thingy that jumps up to wipe the inks.
Apr 29, 2009 | Lexmark X1240 All-In-One InkJet Printer
HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Mar 06, 2009 | HP DeskJet 930c InkJet Printer
Black ink leaking from bottom of printer!
There is a ink resovier where the cartridges are cleaned of excess ink after a job. That gets filled over time and gives you the leakage described. Very messes job to clean it.
Sep 10, 2017 | HP Photosmart 3310 Printer
Ink build up under cartridge
if u look at the back of the unit there is a back door which u can take out .
or u can open the front access door [ from where u insert the cartridge ] , in case u r not able to clean it from there .
u might need to get the unit serviced ,for that either contact HP customer care at 1800 474 6836 or on-site Repair Center at 800-633-3600.
Thanks
May 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Help! Black ink not working
just solved this on my lemark - open the top so cartridges in middle
put cleaning fluid on the 'pads to the right( i userefill kit cleaning fluid) on the 'far right pad' ( the ones that the cartriges sit on when lid closed - they're about under(ish) the on/off switch - i filled the little pads up until almost overflowed (aout 1ml) shut lid so cartridges go back onto the pads, leave for 10 mins, then print out 10 pages of something then repeat the clean again - mine took 3 times then works perfect - hope this helps
Mar 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer seems to be leaking ink?
take those out are uusing off brand ink
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
The printer HP920c ink leaks
The Cleaning station is filled with ink AND the cartridge is broken, this can be caused by using a [poorly?] refilled cartridge.
To solve this you have to disassemble the printer and clean the cleaning station, replace the absorbent pad and replace the ink cartridge.
Sep 05, 2007 | HP DeskJet 920c InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
114 people viewed this question
Ben Johnson
