Question about HP Officejet 7210 All-In-One InkJet Printer
Hp 7210 removing pad for cleaning how do you do it?
How do you remove the pad that is sopping up the leaking black ink? Just pull it out? I removed the cartridges, moved the carriage to the middle and the pad lifts up in the front but seems to be stuck under the small bar ??
Suggestions?
  • 1,031 Answers
U can use a small peg or pin to lift it out
Posted on May 23, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
I am printing an invitation on my HP Officejet 7210 All in One. I am gettting striping in areas which have a lot of solid black. How can I fix this?
From the HP Toolbox on your PC you can run a cleaning page. If that doesn't fix it, or if you are using refilled ink cartridges, it may be time for a new black ink cartridge.
May 02, 2011 | HP Officejet 7210 All-In-One InkJet...
I keep getting an error to remove and check color cartridge. I removed it and found a glob of ink. I tried to remove it and pulled up the top layer of a felt pad. I still have the error. What do I do? ...
CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Copper electrical contacts and ink nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Ink nozzles
  1. Check the copper electrical contacts for debris. If any debris is evident, proceed to "Step two: Clean the cartridge and carriage contacts."
  2. Make sure that the clear nozzle protective tape has been removed. Figure 4: Remove the clear nozzle protective tapec00211538.gif 1 - The clear nozzle protective tape CAUTION: Do not try to remove the copper electrical strip.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423559&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=391182
    please rate me with 4 thumbs up to avail my services in the future and maintain my presence
Dec 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Cleaning up the mess of black ink leaking
You shouldn't need to clean it. Just squeeze it like you would a sponge using something like a paper towel. This is a messy endeavor, be careful.
May 22, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-in-One Leaking Ink
the ink collector(well) hav accumulated much ink overtime its due to be serviced.remove the cartridges move the carriage to the middle remove the ink collector pad and clean , clean the collector with methylspirit check for the sensor beside and clean if blocked
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
Printing Red not Black
remove the black cartrige, check if u removed the plastic protection tape then try to clean manually the print cart. with soft cloth when cleaning.. a black ink should apear on ur cloth if not change the black cartridge
Nov 16, 2007 | HP Officejet 7210 All-In-One InkJet...
Ink leaking problem
There should be a waste bin and it may need to be cleaned. It is like a sponge and absorbs excess ink. It can be removed and cleaned with water. Let it dry fully before putting it back in. This is a messy task so you may want to wear some rubber gloves.
Hope this helps.
Oct 16, 2006 | HP DeskJet 1220c/ps InkJet Printer
Housing removal
If your printer is leaking ink it is most likely that the ink pads are full because the machine has been reset without replacing them. You should contact The Service Manual Shop and get a rescue kit for machine. This will include a service manual to help you pull the machine apart and also has details of how to clean the pads and reset the counter. http://www.TheServiceManualShop.com
Aug 14, 2006 | Epson Stylus C20SX InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
152 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
