Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Same whirlpool ultimate care 2 gripe.
I'm not sure how this works, am I talking to you ronnie204? Oh well, it's good therapy in any case. Does your machine agitate? The way my problem started was about 5 minutes into the wash cycle, it just started making a buzzing sound when the machine should have been agitating or spining. Unlike my computer, car, sprinklers....problems, there doesn't seem to be all that much help out there for washing machines on the net, but I will not pay the people I bought it from 3 1/2 yrs ago $50 to listen to it and tell me it'll be $200 for a new transmission/motor ect..So it's either fix this one or the cheapest replacement I can find, because it appears Whirlpool does not build em like they used to!
Sorry, enough venting, all my research pointed to the coulping, the only way I could check it out was to put it on car jack stands, fill it with as little water as possible and look from underneath. it still made the buzzing sound with the agitator moving very slow & short with both halfs of the coupling moving, but very slowly. I was trying to find out what the normal RPM for the motor should be for spin and agitate cycles, but no joy. All I can think of is either the transmision is binding (not likely, since the coupling didn't shear) or theres a motor controller not sending the right signal (to go faster) to the motor.
Anyway, any idea's or data you can share would be greatly appreciated, maybe togeather we can fix these machines.
Thanks, Good luck, Tim
  • 770 Answers
Sounds like the run winding is out on the motor BTW the whole cabniet comes off the unit so you dont need to put it up on jack stands
Posted on May 31, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Cannot get the casing back on a whirlpool ultimate care ii washer
    You need to set it on the clips in the front at an angle then tip the casing back into position. Here is a video that will walk you thru
    Disassembling a whirlpool style washer
    Oct 23, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool Ultimate care II doesnt' advance through
    Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
    If you find the wire repair it and make sure the wire harness is secure in the provided clips.
    Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    I need to find out how old is my Whirlpool Washer Ultimate Care 2
    The copyright on the owners manual is 2003.
    Here is a -->link<-- to download the manual if you would like.
    Please take the time to give this solution a fix ya rating.
    clarkco
    Feb 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II drum does not spin.
    Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
    Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care 2 leak after wash cycle
    Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
    Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II spins only once in a while :-)
    hi there,
    sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
    also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
    let me know if i can be of more help.
    thanks
    Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool ultimate care 2 washer wont spin
    Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
    Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    66 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
