Question about Apple iPhone Smartphone
Touchscreen and buttons stopped working
IPhone touchscreen, power button and volume control do not work.
  • 56 Answers
U dropped it and spoilt it or either restore it and then unlok it
enjoy
Posted on May 28, 2008
Touch screen not working / not registering touch
Follow the steps mentioned below until your problem is sorted.
1. Restart Your Android Device It works 80% of the time. Screen locking/managing applications often make touchscreen unresponsive. In that case you need to restart your Android device. How can I reboot my tablet, the touchscreen is not working.. Good question!
  • Grab your Android tablet/phone
  • Press and hold the Power Button for 10 seconds or until the screen goes blank.
  • Wait a minute or two and then power on your device normally using the same button.
2. Eject Memory Card and Sim Shutdown your Android device and remove the Memory card and Sim(s) attached to it. Also, remove the battery for few seconds if possible.
3. Remove Any Cases Smart cases are good in protecting your device from scratches and damage. But their automatic screen wake/sleep feature sometime cause the device to malfunction. Remove the case, perform a restart.
4. Hard Reset your Android For advanced users. If everything else doesn't work, try doing a hard reset on your phone. This will wipe your phone/tablet and return it to its original condition. This usually involves holding down Volume-Up and Volume-Down button together and then pressing Power Button (every phone has different method). It starts your device in Recovery mode, you can do a Wipe-Factory-Reset from there. Use volume up/down buttons to navigate and press Power button to select. Be careful and don't mess with other options or you may brick your phone.
5. Knocking the Touchscreen (Not recommended) Remove the Screen Protector on your Android device if present. Now, gently knock every corner of your touchscreen to realign it. Sometimes continuous phone drops cause screen digitizer cable to loses its connection to device motherboard however, its a rare case.
If you are still unable to make touchscreen work maybe its time to claim warranty, Its a lengthy process but works. Also, post comments below to share other tips not mentioned in this article.
May 29, 2015 | Cell Phones
Tip
Hard reset for Nokia,HTC,BlackBerry,Iphone,Sony......
Hard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus. if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you......... All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile =>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well. HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction... IPhone 3G,3Gs, IPod Touch,IPad... =>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously . - Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo . For IPhone4 is no need to turn off as normally =>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation -slide across the red slider -hold two button above to turn on... * Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen . Nokia/Touchscreen with keyboard/N97,N97 mini,... =>Press and hold button shift/left+space+backspace,including power button and follow in struction... Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6... =>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem.... * for N8 =>press volume down+camera+menu,including power button... Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60 =>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well. * For Nokia,if the operation require code,the default code is 12345. * S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too. BlackBerry =>Press and hold Alt+Shift/right+Del,then follow the instruction... SonyErisson/Touchscreen with keyboard =>Press and hold right + left soft key,including press power button.../was try on X1i,no problem... SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research. You should know that Hard reset is the last solution,if none solved ur mobile problem. Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk -kindly do not edit this document.... :) Research and Prepare by YEKCHHUNHOUR. Inform me if you see any wrong instructions,to improve this doc better and confiding. Via Email: Chhunhour.kh@hotmail.com 27/12/2010
on Jan 01, 2011 | Cell Phones
Tip
Any phone Hard reset
HARD RESETHard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus.if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you.........All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile=>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well.HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction...IPhone 3G,3Gs, IPod Touch,IPad...=>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously .- Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo .For IPhone4 is no need to turn off as normally=>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation-slide across the red slider-hold two button above to turn on...* Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen .Nokia/Touchscreen with keyboard/N97,N97 mini,...=>Press and hold button shift/left+space+backspace,including power button and follow in struction...Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6...=>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem....* for N8 =>press volume down+camera+menu,including power button...Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60=>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well.* For Nokia,if the operation require code,the default code is 12345.* S80 press and hold Ctrl+shift+F* S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too.BlackBerry=>Press and hold Alt+Shift/right+Del,then follow the instruction...SonyErisson/Touchscreen with keyboard=>Press and hold right + left soft key,including press power button.../was try on X1i,no problem...SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research.You should know that Hard reset is the last solution,if none solved ur mobile problem.Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk-kindly do not edit this document.... :)Research and Prepare by YEKCHHUNHOUR.Inform me if you see any wrong instructions,to improve this doc better and confiding.Via Email: Chhunhour.kh@hotmail.com27/12/2010 VOTE FOR ME PLZ..........
on Dec 31, 2010 | Lands Phones
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
I have an htc inspire and the touchscreen stopped working/ is frozen, how do I get it to respond or will I have to replace the touchscreen?
Please follow the following procedure to hard reset ( factory reset ) the phone . If that does not help Please take it to a authorized service center .
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 10, 2011 | HTC Inspire 4G Smartphone
Screen freezing touch screen not working samsung pixon
The problem is a faulty contact from the touchscreen leading to the phone board.
On the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screen's face a little from the phone body exactly at the volume down button(using your fingernail or something) and see if the touchscreen is responding in anyway. Now try to pull a little bit the touchscreen frame from the rest of the chassis and see if it works.
Be careful though not to totally destroy your phone...
Jun 28, 2011 | Lands Phones
Touch screen not working right
try pressing the reset button(pinhole) at the right side of it using a pin
Jun 21, 2009 | Digital Mind Corporation iQ Sound...
Iphone keypad not working
First try a hard reset. Hold down the power and home button simultaneously for 10 seconds until the iPhone reboots.
If that doesn't work you need a new digitizer. If it's a 3G I would advise replacing the digitizer. If it's a 2G I would not advise replacing the digitizer b/c you would have to replace the LCD, Digitizer, and the Glass Panel and the cost would exceed $100.
You could also consider selling your iPhone AS IS for parts or repair on eBay, Craigslist, BuyMyTronics.com or I could make you an offer.
Hope this helps, Rate me please!
Jun 17, 2009 | Apple iPhone Smartphone
My touchscreen does no work and games don't play right
The touchscreen replacement isn't too bad if you've got some technical knowledge, about 1 hour and a lot of patience.
I'd get the new touchscreen from a popular web auction site and the replacement is quite straightforward but fiddly, if you can wait for the new touch screen to arrive in the post, have a tri-wing screwdriver and a lot of patience you might as well go for it. Just take great care when replacing the bottom case to line up the power switch (and volume control) with the external plastics so as not to cause any damage as a broken power switch isn't an easy replacement.
HTH
Mar 06, 2008 | Nintendo DS Lite Console
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Jan 12, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
96 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
