Question about Zanussi FLA1001W Front Load Washer
How to replace the belt on zanussi fla1101w
Do you know how to get a new belt on the zanussi. Working from the top of the machine I've looped the belt around the motor wheel first then tried to get it on the drum wheel but it's just too tight. Is there some method of doing this?
  • mefatcat Jan 22, 2009
    zanussi TC-481w need to replace broken belt. how do you do this?
    President:
  • 1,462 Answers
Just struggle i'm afraid. put belt on motor pulley then start it on the drum pulley. turn the drum pulley and it will go on but very tight
Posted on Jun 30, 2008
How do you change the belt on a zanussi nexus fl 1082.iv got the top off and tryed to slip my hands down the back of machine to attach the belt to the motor and wheel,but just cant get the last bit on,and...
With the help of someone, tilt the washer forwards towards you, this will give you more room to get your hands inside to fit the belt, it is awkard, but can be done, I have done it this thay on many occasions, otherwise, it entails removing the rear half of the cabinet, not an easy job!!!!!¬.
Good luck.
Oct 12, 2010 | Zanussi FLA1101W Front Load Washer
How do you remove back panel on zanussi fls-1183w so i can replace belt
you only need to remove the top of the machine but be carefull when fitting new belt
Oct 05, 2010 | Zanussi Washing Machines
Sticking mid cycle.
suspect heater circuit or pressure swirch
Jun 28, 2010 | Zanussi FLA1101W Front Load Washer
Broken bearing
not sure whay you wish to know, replacing the bearings is quite a big job/ expessive if over 5 yrs old suggest new machine....
Feb 23, 2010 | Zanussi FLA1101W Front Load Washer
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
Jan 11, 2010 | Zanussi FLA1101W Front Load Washer
The letters on the program selector have worn off
replace with new one and put clear nail varnish over print :) so wont happen again01179512835
Dec 30, 2009 | Zanussi FLA1101W Front Load Washer
Does not spin
Hi friend
did you see anything stuck under tub ,,,,,,if not then its a timer problem,check it...
thank u,,
May 03, 2009 | Zanussi FLA1101W Front Load Washer
Zanussi Model FLA 1002W Washing m/c.
my w.m. is very noisy, after cycle laundry is with black spots on and white bits on clothing but it is not tissues. ?
Feb 13, 2009 | Zanussi FLA1101W Front Load Washer
My zanussi washing m/c is leaking from the front of the drum
Could be door boot seal or indeed the drum having a hole in it, the seal is simple to do drum is not worth while.....Although a good grade Silicone would seal it...
Jan 08, 2018 | Zanussi FLA1101W Front Load Washer
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
Zanussi FLA1001W Front Load Washer Logo
324 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
