Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Blue dots (small points) and big yellowish spot on the screen
When my projection display is turned on, the screen shows many blue dots (points) at the left side (more than 30). There were only a few ones (approximately 10) the first time the dots appeared, but as the days go past, the number of points increase. The operating instructions manual does not contain anything about this type of situation. Does it mean that the display needs cleaning or repair? How can I solve it?
Also, the display shows a big yellowish spot from the middle to the bottom of the screen. People look yellowish. Please let me know if it is a damaged part, which one, and if I can replace it.
  • Anonymous Aug 08, 2008
    blue spots in an almost milky way-like pattern in the middle of a rear projection monitor
  • 37 Answers
Need a new bulb
Posted on Mar 13, 2009
Blue spots on screen
Most likely the LCD panel is failing. These are "stuck pixels". Common with early LCD displays used on DLP TVs.
Jan 22, 2014 | Mitsubishi 60inch 3-D Ready 1080p 120Hz...
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Blue smears and dots on the screen and a orange yellow picture
Bad Light Engine/optical ASSY Encompass Parts Distribution 1-800-638-3328
Jun 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Small blue dots clustered when the screen is dark, near the projection point.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 29, 2010 | Sony KDF-E50A12U 50" LCD HDTV
When the set is turned on, the screen displays a lot of blue dots like an outer space scene except the stars are blue and there is a large circular area in the middle that is yellowish. I still get a...
Hello: Unfortuntely the Optics engine will need to be replaced the blue lcd chip is failing, this will get worse as time goes on. Replacing the optics engine is the only solution to repairing this set back to spec's. Most call them Light Engines..This site will give you cost and example of what one looks like.
Http://www.tristatemodules.com
Nov 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue dot on screen really small but noticable if you know what your looking for wondering if its a problem with the projection or if its a quick fix
If it's a CRT projection TV, it could be a burned spot in the phosphor of the blue crt. If it is a burned spot, I don't beleive there's a fix.
Oct 20, 2009 | Toshiba Televison & Video
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
I have two small blue spots on my big screen
you cant remove those spots as they are referred to as 'dead pixels'
im guessing your warranty is already finished, so you'll have to get in touch with the manufacturer and they might be able to give you a few names of places that can fix this in your area.
also, unfortunately, the only way you can prevent anymore would be to stop using that tv. :(
Jun 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
233 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
