Question about Casio Exilim EX-S600 Digital Camera
Ugh hi my camera wont work unless its in the charger and when it is in the charger it will only show the pictures. The lense wont come out. :/ help
  • kels4588 Oct 01, 2008
    Mine does the same thing! The camera worked perfectly until this! The red light for charge is steady for about 5 seconds then it starts blinking. I can't turn my camera on while it's in the base, but if I push either the "photo" or "USB" buttons I can get inside the camera.
  • LAS97045 Oct 03, 2008
    Our camera has done this twice now. Once we sent it in for warranty repair and it came back working great, but now has started doing it again. Won't seem to recharge and can't do anything with it unless it's in the base
  • 374 Answers
Does the light blink while it's sitting in the charger? If so call tech support and see if they will replace your battery.
Posted on Sep 10, 2008
Why I CAN'T TAKE PICTURE?
The first thing I would do is check is the battery and charger. The L810 switch will not function if the battery is too low. If the battery is old, it may appear to charge, but not hold the charge. If it is over two years old or if you leave it unused without recharging it for extended periods, I would buy a new one. The charger could also have a problem. If a new battery does not work, replace the charger; it is not expensive. If all else fails, call Nikon Service to arrange repair at 1-800-645-6687 from 9AM to 8PM EST, Monday to Friday.
May 25, 2014 | Nikon COOLPIX L810
My camera is a vivitar pink (MID0050609) and it wont turn on, unless i plug it it to my charger and when i do the light on the left is red and it just blinks then flash a blue screen turns on that says...
MSDC is not a problem code. It is normal, the camera is informing you that it's connected to a computer. At this point you should see a new "drive" show up in my computer to transfer pictures.
Have you tried turning the camera on when plugged into a wall charger? If it turns on using the wall charger it might need a charge over night. If the camera will still not turn on after a charge the battery is dead and needs to be replaced.
Mar 12, 2011 | Cameras
The camera is not connected
if this refers to a lower end nikon camera, it will not show that it is connected to non afs lens unless it is in manual mode. Auto will not work with manual lenses or lenses that do not have motors in the lens.
Feb 27, 2011 | Cameras
My Camera lense doesnt come out all the way
The optical block (zoom lens) needs replacement, The detail of part is given below:
Part No. Description
A-1512-913-A LSV-1250A
Replace the given part and your camera work fine again.
Thanks for using fixya.
Jul 27, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
I have a SANYO VPC-T1060 i accidentally dropped it and it turned off with the camera lense out , i tried to turn it on but it wont
Usually when a digital camera has lens issues, they will turn on very briefly, then turn off. Try holding the bottom button in on the lcd side as you push the power button to see if your camera will display stored pictures. My daughter dropped her boyfriends 1060 in muddy water the other day and I cleaned it enough to get it to show pictures but couldn't get the lens to work. A drop or a speck of dirt will stop the lens from working. Haven't had much luck getting lens unstuck, but have replaced the lens unit, usually better to buy new camera unless you are very handy and can find a 1060 with a good lens and bad LCD, which I have done a few times. Looking on Ebay, most of the 1060's being sold 'as is' have bad lens and good LCD's......not good for us....hope this helps.
Apr 19, 2009 | Cameras
Screen error!
Sorry to tell you but I think you have a bad cable on your CCD. You have to take it to be repaired at a shop.
Jul 22, 2008 | Fuji FinePix F470 Digital Camera
Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Aug 24, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
27 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
