Question about Dell Inspiron 5100 Notebook
Laptop power lights won't come on
Plugged in ac adapter and green light is present on the adapter but the power lights on the laptop don't come on. Is the Mobo dead or is there something else I can do to get it to turn on?
  • jander1900 May 22, 2008
    None of the lights on the laptop come on, only the indicator light on the ac adapter. Not sure if the battery is dead or not. There is no external indicator on it, only power levels when the computer is on. I didn't think about radio shack, I'll give it a try. thanks.
  • Anonymous Dec 09, 2008
    i have an averatec 3150 and the ac adapters working but the charge light wont come on were do i need to take it
  • 72 Answers
Does neither the charge nor the power light come on? Most Dell batteries have a button on them that you can press to determine how much power it has left. If your battery still has power try turning the computer on, and once you get into Windows see if it will detect the power cord or not.
If you can't get the machine to boot you can try your local Radio Shack. They normally have adapters for every laptop, and ask them if you can try it in the store to get your computer to turn on. If that cord works then something is wrong with your AC adaptor.
If neither cord works then either something is dead on your motherboard, or the power jack on the back of the laptop is loose (and not providing any power.)
Posted on May 22, 2008
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
No a/c power light on laptop
Well the first thing you should check is the amount of power output to the power supply. for example the computer needs 12V but the AC Adapter only gives 9V.
If that's not it then the actual green light is not receiving that information from the motherboard. that's not an issue if the battery get's filled up and the laptop works normally . If you notice that the laptop tends to shut down quickly when it's not plugged in then the battery is worn out. These things happen since the a laptop battery becomes very inefficient after 2-3 years.
One more thing - try to rotate the input end of the ac adapter cable. maybe it's not making good contact inside the laptop.
Hope this helps.
Feb 02, 2012 | Gateway MT6705 Notebook
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
Sep 03, 2011 | Computers & Internet
If left unplugged fro the laptop for a few hours, or if the charger itself is moved from room to room, occasionally we get an issue where the green light that indicates power does not show up at all. The...
If light you are talking about is on the power supply itself, you need to replace the power supply. Look on E-Bay.
If the light you are talking about is the AC power light on the laptop, then there are two things that are most likely. First is the power receptacle in the laptop. I have personally seen many of these fail. The other thing is the battery. With the system Off, and power supply disconnected, remove the battery. Wait a couple of minutes and put back in and plug in charger. If it continues to happen then it is most likely the power receptacle in the laptop.
Best of luck, Jim
May 07, 2011 | Ultra Products ADP-65JH DB Ultra Slim...
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
AC Adapter
Two possible solutions are present; one is that you have terrible luck with said adapters. The other is that you're using adapters with too much or too few milliamps or volts. If the specified rating on the adapter doesn't exactly match the power consumption for the computer, then it will become strained or vice vera and it won't work.
May 26, 2008 | Dell Computers & Internet
Dell Inspiron 5100 Notebook Logo
207 people viewed this question
Alun Cox
