Question about Frigidaire TGF317 Gas Kitchen Range
Oven not working but burners are...
The range is Frigidaire, not sure which model. It was in the home when I moved in. It's a basic model, 4 burners, oven/broiler, propane.
Checked inside the broiler and saw the orange light...assuming this lights it. Left it on for 5+ minutes and no heat. I looked to see if the holes for the burner might be clogged but they look clear.
Tried turning valve off then on.
Thanks for your help.
Karma
    President:
  • 1,314 Answers
Replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
Posted on May 22, 2008
Electric control panel on gas frigidaire stove
Hello Tim;
My name is Peter. I am a retired field service appliance technician, with a customer base of 25 families on the side. I love the work.
You did not post your range model number which is on a label either on the face of the oven when you open the oven door or on the side of the oven door.
Gas ovens have the same basic operational functions however, the components to initiate these functions is different depending on your model number.
1.) Ignitors - Your gas range has separate ignitors for the oven and the broil operation. So, failure of both at the same time is not the problem.
2.) Main Control Board - Rarely is this the problem if your burners are working.
3.) Gas Safety Valve - Has 2 lines coming off it. One to the top burners and one to the oven. Maybe, it happens, but it is rare.
4.) Main Gas Valve - Has two coils which may be bad. But, low probability.
5.) Thermocouple - High probability, if you only have one thermocouple for both the oven and broiler.
6.) Oven Control Board - This is a high probability. This is a smaller control board than your main control board. This board controls both your broiler and oven.
You can go into the following website, put in your model number, and get both diagrams and component part numbers.
You can go into this website and purchase from Sears, or you can record the model number, search the web and purchase a $200.00 part for about $40.00. Purchase used if you can. I do.
If you decide to go with the oven control board, make sure you ground yourself by touching bare metal. Static electricity will knock out a board. You should receive the board in a anti-static silver bag.
Remember, I do not have your model number, so I am guessing based on my professional experience.
Water Filters Lawn Garden Appliance Parts
Mar 21, 2016 | Frigidaire Kitchen Ranges
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
Ancient (1971) Frigidaire Cookmaster electric Compact 30 Range/Oven, model number RBG-533N, has two surface mounted red indicator lamps; one for the oven & one for the burners. The surface burner...
The stove has 4 burner switches with a # 2 terminal on each switch. This contact is similiar on all four switches. One of the switches # 2 contact is stuck. The burner switch should disconnect both legs of the 240 volt circuit, one leg through the # 2 terminal and one leg through the thermostat built into the burner switch. Disconnect the pilot lamp wire on each switch unti the light goes off and then replace that burner switch. This should correct the problem
phucks001@horrycountyschools.net
Oct 08, 2010 | Frigidaire Kitchen Ranges
Oven does not maintain temp.
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Feb 20, 2009 | Frigidaire FGF316 Gas Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire oven burner will not shut off
Dont know what model you have, but the timer may have been moved and it is on manual Will it turn off if you turn temperature control down. Do you think the theromostat is working. Sounds like your clock may be operating the oven.
Nov 05, 2008 | Frigidaire Kitchen Ranges
Self cleaning oven
http://www.frigidaire.com/support/Result... just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
242 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
