Question about Avanti Kitchen Ranges
Where can I find someone who services Avanti ovens?
    President:
  • 1,314 Answers
Http://www.avantiproducts.com/index.php?page=contact you can go there but whats wrong with it
Posted on May 22, 2008
Service manual of macrowave Avanti M09003SST
You can't get service manuals as there are no user serviceable parts. Only dealers can get them. The screws holding the case as security screws which only dealers have the tools to open. Microwaves can kill and blind you in 15 seconds.
No puede conseguir manuales de servicio ya que no hay elementos manipulables. S?lo los distribuidores pueden conseguir. Los tornillos que sujetan el caso como tornillos de seguridad que s?lo los distribuidores tienen las herramientas para abrir. Microondas pueden matar y cegarte en 15 segundos.
Dec 12, 2015 | Avanti M09003SST Microwave Oven
HOW TO CHANGE FUSE
you should not touch electricity
too much can go wrong
call someone qualified
Mar 28, 2015 | Avanti Convection Oven with 2 Burner...
Mkb42b not hot enough
this sounds like your magnetron is starting to wearout
Mar 28, 2014 | AVANTI-SMALL APPLIANCES avanti mirror...
E4 error message
The E4 error code is a result of a malfunctioning defrost sensor. If the error code is on the right then it is the defrost sensor in the upper chamber.
Attached is a link to Avanti service and parts. Provide them with the model number of your wine cellar and they will be able to provide you with a price and information on the part needed for repair.
http://www.avantiproducts.com/index.php?page=contact
If you have the owner's manual or are able to speak with a service technician through Avanti, then this can be a diy repair.
Sep 06, 2013 | Avanti WCR5450DZ
Looking for parts for Avanti g20aw
Go to www.repairclinic.com. You will need the model number. You will see all the parts available for this unit. Good luck.
Sep 29, 2009 | Avanti G20AW-1 Gas Kitchen Range
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Feb 19, 2009 | Avanti DER24CSS-1 Electric Kitchen Range
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Dec 03, 2007 | Avanti ER24AW-1 Electric Kitchen Range
Kitchen Ranges Logo
171 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
