Question about Sharp AL 1631 Copier
Really in need of help
Opyes started coming out with gray background, no error code was showing, but now L1 is flashing. Already tried with reset 14, but seems the carriage is stuck. I would like to remove the glass and check what is stuck, but I[m not sure how to do it safely. Please help me asap! Thank you guys.
  • 146 Answers
Most likely the scanner lock underneath the scanner (where the paper exits) got locked. It should be a round plastic knob. If that it not it you need to check the travel of the mirror system and lubricate the scanner rails. IF YOU DO NOT HAVE EXPERIENCE WITH OPTICAL SCANNER SYSTEMS DO NOT ATTEMPT TO REPAIR IT. IF THE CABLES SLIP OFF YOU ARE DONE. I've been a copier tech for five years and it took me four hours to restring the optics cable on a Kyocera and eliminate the skew.
Posted on Jun 06, 2008
Why does remote UMC-117 flash error code 11 and then L1?
Multiple error codes can mean bad PC board.
C11 is combustion, vent or gas issues
L1, heat exchanger needs delime.
Catch unit up on required maintenance each year.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Gene
Water Heater Timers Save Money
Jun 17, 2014 | Rheem Tankless Water Heater Main Remote...
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
My AR M160 digital imaging copier keeps blinking with 4H showing and I cleared the paper jam, all intact, and now nothing but the blinking 4H. please advise
H4 (and other) Error Reset Code:
Press "clear" "interrupt" "0" "interrupt" in succession and machine will blank off
Using the numeric keypad make the display read "14"
Press the "copy/start" key
Good Luck
Nov 09, 2009 | Sharp AR-M160 Black and White Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
Eror code on sharp copier AR-M276
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Jun 24, 2008 | Office Equipment & Supplies
Sharp copier model no. DM1505, will not copy
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
May 17, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Flashing error code
Dec 20, 2007 | Toshiba e-Studio120 Copier
Error L1
There are a couple of things to try . First try this to see if this resets the problem..
If this reset does not correct it, see if your your lamp carriage, under the glass is moving freely. You may have to remove the glass WITH THE POWER OFF, and see if it moves freely.
Listen and feel carefuly for the lamp making some contact with a sensor or bracket.
Other then that the other cause is the scan motor being plugged in backwards, I seriously doubt you have done that one.
Hope this helps, If not tell me and I will look into it a further, but either a reset 14 or the lamp catching on the home sensor bracket should resolve this.
Dec 19, 2007 | Sharp AL 1631 Copier
Flashing 4-H error message
try this reset procedure. Most likely this will work.
Nov 29, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
134 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
