Question about HP Photosmart C3180 All-In-One InkJet Printer
My printer calibrates every time i turn it on
How do i make it stop?? I-ved just bought a new cartage and now its gone mad!
  • moomi May 22, 2008
    i thought it was a driver thing but have reinstalled it all. wont print any colour, though I currently only have ink in the photo cartridge, the tri colour one is in the machine but empty. when trying to do the maintenance it wont print when you try & do the clean.
  • sandman84 May 30, 2008
    in the scan or in the white paper box?
Just put the printed page upside down in the printer & press Start Scan. Works!!!
Posted on May 30, 2008
I bought a new HP OfficeJet Pro and it said to replace the "magenta ink cartridge". I bought a new HP cartridge and it still says the same thing!
Hello, This could be a little tough, because the printer is suppose to recognize when the toner has been changed. I see that this has not happened.
Steps 1) You should make sure the toner is firmly seated into the printer.
2) Compare all the printer electrical contacts against one of the known good toners.
3) You could try and force the printer calibration,
*** do not tip the toner on end ***
1 Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight PRINT QUALITY.
5 Press to select PRINT QUALITY.
6 Press to highlight CALIBRATE NOW.
7 Press to select CALIBRATE NOW.
8 Wait for the printer to calibrate.
If none of the above tips resolve your issue, you may have to have the printer serviced.
Follow the links below to verify HP Warranty and Repair Center Locator
HPPARTNERLOCATOR
HPWARRANTY
Jan 16, 2011 | HP LaserJet 4600dn Color Printer
Printer shows no cartage found
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad.
HP :- 1-800-474-6836 ( Tech Support )
May 11, 2010 | HP PhotoSmart C4385 All-in-One Printer
Can't get my color cartage to print on my canon prima mp160.
Hi there not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then
Jan 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Kodak ESP3 verses Windows Vista!
I have a suggestion that might work.
Is your User Account Control turned on? If it is, try turning it off,reboot, and try to reinstall your drivers.
This feature of Vista is notorious for blocking new drivers. It was so bothersome to me that I leave it turned off permanently.
User Account Control can be accessed through Control Panel/Security Center.
Feb 06, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
The Printer is not sensing the Black Cartage
if their cartridge worked and yours did not. buy a new cartridge.
Jan 27, 2009 | HP Officejet Pro K5300 Laser Printer
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Allignment
when you insert the new cartages then when the align page will print put it in the scanner and scan it once the align page will be scanning it will not print the align page up to you not change the cartrage
Jul 26, 2008 | HP PSC 1510 All-In-One InkJet Printer
Put in new cratridge
when you installed the new one cartage then every time your printer will be align cartage and if the printer was not detect the alignment page properly then every time he will be align
so when the align page will be printed it will can properly once it will detected then the alignment page printing will be stoped
Jul 17, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
