Question about ASUS GeForce 8600 GTS, Graphic Card
ASUS NVIDIA GeForce 8600 GT Graphics Card
I have a dual boot WinXP & Vista Asus system. The MOB is ASUS P5K-SE S775 with an Intel E6850 with an Asus EN8600GT Magic 512MB. When I boot in Vista the monitor re-adjusts it’s self to center the Video signal and all looks good and usable. When I boot into XP it does not adjust and the image is over scanned and the start button is unseen. The resolution glitch happens at all resolution and I natively run at 1224 by 768 which is comfortable for my eyes. I have the latest drivers. The monitor can be manually adjusted to fit the image which resolves the overscan. But Vista resets the monitor automatically. Speaking of monitors I’ve tried on a Dell 22”; EMV 17”; Dell 17” and an Apple 20” display and it occurs on all of them, so it’s safe to say it the Asus Video Card. Can someone point me to a fault finding process I’ve not covered/ or why this is happening. Thanx
  • 508 Answers
Try to reinstall driver for xp from here:
http://www.nvidia.com/object/winxp_181.22_whql.html
Posted on Jun 02, 2009
Does p5k se motherboard support with GTX460 ?
If you are talking about the Nvidia Geforce gtx 460 video card working with the Asus p5k se motherboard?! YES!! That motherboard should have a pci-e 2.0 x16 expansion slot with is what this video card needs.
Hope this helps!
Jan 23, 2011 | ASUS P5K SE MOTHERBOARD (4719543152829)
Give me driver
Hello tb_cheem , You can download latest driver for ASUS V9570LE nVIDIA GeForce FX 5700LE from nvidia website fully compatible with Windows Vista, Xp. Click save driver to your computer, install the driver, don't forget to restart the computer.
Copy and paste link into your browser and press enter.
Here is the link:
For Windows XP
1. http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/175.19/175.19_geforce_winxp_32bit_english_whql.exe&lang=us&type=GeForce
For Windows Vista
2. http://www.nvidia.com/content/license/location_download_nvidia_us_beta.asp?kw=&url=http://download.nvidia.com/Windows/96.85/96.85_forceware_winvista_x86_international_whql.exe
Good Luck!
Nov 29, 2010 | ASUS V9570LE nVIDIA GeForce FX 5700LE GPU...
My geforce 9400 GT will not properly install drivers in my ASUS M2V-MX SE. When install the nvidia drivers old and new. the video card has a yellow exclamation next to it
If you uninstall the onboard driver and then update the new cards driver in device manager the problem should be solved.
If not you can always reinstall your operating system, that usually solves any driver issue.
If that doesn't work then your card is most likely not compatible with your motherboard.
Jun 07, 2010 | ASUS NVIDIA GeForce 9400 GT,, PCI Express...
Blue screen of death.
You might try setting the display adapter in the bios to PCI-X,
You could also try going into safe mode to see if you can install the new drivers and fix the problem.
Other than that you would need to stick the card in another computer and confirm whether it is functional.
I have the exact same card with Vista and had no issues, and have been very happy with it.
May 11, 2010 | Palit Microsystems GeForce 9600 GT, PCI...
How do I add a second nvidia geforce 7600 gt card to my ASUS A8N-E Motherboard
There is only one slot for your video card but you can get dual power of graphics by adding Nvidia Geforce 9800 gtx2 card.
Oct 20, 2009 | Computers & Internet
Can i put nVIDIA geforce 8600 on my p5sd2-vm
Yes, your Asus motherboard will support the Nvidia GeForce 8600 PCI-Express graphics card.
However one thing you should consider. The 8600 card is SLI compatible but the motherboard only has one PCI-E x16 slot.
You will also need to make some changes in your bios.
In order to help you configure your system for a PCI-E graphics follow these steps.
1. Uninstall your current display driver software through windows control panel. Windows may ask you to restart your system, do not restart. Shut windows down which will shut off the system.
2. Unplug the power cable from the system & open your case.
3. Install your 8600 card. (Double check it is installed correctly & if needed has the extra power cord connected to the card.
4. Re-connect the power cord.
5. During boot up enter the bios by pressing the Delete key every couple seconds.
6. Once in the bios click the Advanced tab, see top of page 2-19 in your manual.
7. Than open Onboard Device Configuration
Open North Bridge Configuration, see page 2-22
Change Primary Graphics Adapter to [PCI-E]
Change Internal VGA to [Disable]
Change Share Memory Size to [Disable]
8. Save Bios changes & exit. Your system will auto restart.
Once windows has finished loading install the 8600 driver software & directX 10.0. You can also go to nVidia & download the latest software driver @
http://www.nvidia.com/Download/index.aspx?lang=en-us
Thanks for using FixYa!
Mike
Jun 19, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Screen not starting after installing graphics card
Hi rohit1987,
The XFX NVIDIA GeForce 8600 GT 256MB DDR3 PCI Express card uses two DVI ports on the back of the card. Display is most likely coming from the second port. Try moving your monitor cable to the next DVI port. You can do this while your system is running.
If you still do not receive display, post that here & we'll go over some other possibilities.
Good luck rohit1987!
Thank you for using fixya.
Mike
Jan 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
ASUS GeForce 8600 GTS, Graphic Card Logo
477 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
