Question about Memorex Televison & Video
Dvds are not allowing me to record on them - Memorex Televison & Video
    President:
  • 2,712 Answers
It could be that the DVD's are defective. Try using a different batch. You can also try using a DVD lens cleaner..
Posted on May 22, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I have a Toshiba DVD recorder and I keep getting error code E3 28031100 and a window that says the disc cannot be recorded on. Discs are new or in good shape but, won't play/record. Any solution?
SOME DISCS HAVE SAFETY FEATURE WHERE IT WILL NOT ALLOW YOU TO RECORD IT AND ITS JUST NOT POSSIBLE ON NEWER DVDS BECAUSE OF THE WHOLE PIRACY CASE
Nov 27, 2016 | Toshiba Televison & Video
The manual for my DVD-V3500 says that you can't record from DVD to the VCR. But, can you record from the VCR to a DVD?
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
Feb 03, 2011 | Samsung DVD-V3500 DVD Player/VCR
Will play commercial dvds but will not play home recorded dvds
The home recorded dvds disc have diffrence finalizing codes,that the Panasonic dvd recorder doesn't share those codes.That why u can't play those home recorded dvds discs.
Oct 24, 2010 | Panasonic DMR-E55 DVD Recorder
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
I have got the disk to unfinalize but I can't delete anything. I want to start over with DVD-RW but I can't.
Unless you recorded in VR mode, then you will not be able to delete single video clips. The only option left for you is to "initialize" NOT "unfinalize" the disk, (warning: this will erase your ENTIRE disk). Once you initialize, you will have an empty disk to re-record on. VR mode allows more editing and delete options but DVDs recorded in this mode are not compatible on all dvd players.
Jun 10, 2009 | Canon DC210 DVD Camcorder
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Cannot Read Some Recorded DVDs
Not all disks are compatible and you have just found this out for yourself. Stick with what works.
Jun 20, 2017 | Lite On LVW-5045 DVD Recorder
Will This DVD Recorder Burn DVDs from a Desktop?
Ive never seen a standalone DVD recorder that can connect to a pc unless it had a Hard Drive. This model is a Target exclusive company. These devices are designed to record video direct from either Antenna,Cable,VCR,or something such as a game console, or camcorder.
Hope this helps!
May 01, 2008 | TruTech T650-DR DVD Recorder
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
I cant record
I posted this in another person's question but it is probably relevant to you as well. This model (which I own myself) is outdated and needs a firmware upgrade. You might get lucky and get one from their tech support. However, I heard they stopped shipping them nearly a year ago. As it stands your recorder can only use DVD-R that records at 4x (or lower) and DVD-RW that records at 1x. Any other media is useless. Since 4x media is outdated, it may be hard to find at a major retailer. Let me know if you have any luck fixing this or finding working DVDs as I have had the same issue myself. I simply cannot find 4x DVDs in the store.
Jun 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Televison & Video Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
