Question about Canon PIXMA MP130 All-In-One InkJet Printer
Paper Feed is Jamming
When I go to print a document, the paper bunches up on the right side (facing printer) and doesn't get fed into the printer at all. All that happens is my paper gets ruined and I waste ink on nothing. There isn't anything visible blocking the feed rollers, but I can't figure out what else could be going on. Any suggestions?
  • 1 more comment
  • Anonymous May 22, 2008
    canon pixma MP160
  • alien15 May 27, 2008
    I have got the same problem with my MP130. The difference is it is getting jammed on left side (facing the printer).
  • Ray rob May 28, 2008
    I have a piece of paper jammed on the right side (facing the printer) and can no means to retrieve the paper that is jammed
  • 27 Answers
Unplug the power cable and the usb cable from the the power buton for 20 sec........its to release the static from the printer...replug all the cables......printer would work properly now
Posted on May 22, 2008
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
When printing, the paper gets pulled slightly to one side (to the right when facing the printer) and ends up not being fed through.
i used samsung laser printer now toner exhuastet show error and red led glowing.Please help and give the solution
Mar 05, 2010 | Epson Stylus Photo R220 InkJet Printer
Hp l7590b no paper load
hi friend,
Step 1Turn on your printer. Make sure it is plugged into an electrical outlet and installed properly.
  • Step 2Wait for your printer to stop. Do not load paper while it is printing or running any kind of maintenance operation.
  • Step 3Prepare your paper. Make sure your paper is right side up (glossy, whiter or label side should be facing up). Make sure all the pages are lined up together, like a deck of cards.
  • Step 4Locate your paper tray. Some printers have a manual tray and an automatic feed tray. Refer to your printer’s documentation to find the automatic feed paper tray.
  • Step 5Place your paper in the tray. For 8.5 by 11 inch (standard) paper make sure the 8.5 inch side will be fed into the printer.
  • Step 6Set the paper guide. This is the movable piece on the side of your paper tray. One side should move and the other should not. Move your paper so it touches the side that does not move, and slide the paper guide so it touches the other side. Some paper guides have markings so you can set it to the exact measurements if you know the size of your paper.
  • Step 7Set the paper thickness lever. Refer to your manual to determine which setting this lever should be at. Generally, standard paper does not need a different setting and special media like glossy photo paper or envelopes should use a thicker setting. You can usually access this lever the same way you access your ink cartridges.
  • Step 8Let your printer know what it is printing. If you are using a special media, then set the options before you print. Click “Properties” on the print dialog before you print something. From there, change your media type to whatever kind of paper you loaded.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Fan your paper back and forth before lining it up to load into your printer. This prevents static build up which is the leading cause of paper jams.
    • If your printer doesn’t feed the paper correctly at first, try making slight adjustments as it tries to feed to find the right spot.
    • Refer to your manual for in-depth paper loading instructions.
    • Many printers have a resume/cancel button. This is to be used when you need to load paper mid-print job.
    • Do not overload your printer.
    • Avoid non-standard media types such as loose leaf paper with holes or folded or wrinkled paper or anything with affixed stamps or stickers. These can jam your printer.
    hope this helps u
    please rate me...........................
    thak u for using fixya
    Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Whitch way does the paper go in for faxing ?
    If your using the feeder on the top of the scanner, it should go face up. If you are faxing from the glass - face down.
    Oct 29, 2009 | HP Officejet 6500 Wireless All-in-One...
    Printer prints ldocuments but will not print
    In Word you create the envelop, specifying the dimensions and the way you will load it (face up or face down). Then you remove the sheets of paper and place a stack of envelops, and adjust the feeder so that the envelops won't drift while they are being fed.
    Hope it helps
    Aug 30, 2009 | Dell Office Equipment & Supplies
    Photosmart 3210 all in one printer
    Turn the printer around and open the door you will see paper jam.
    Jun 30, 2008 | HP Photosmart 3210 Printer
    Dell 924 All-In-One printer
    Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
    • Letter*
    • Legal
    • B5
    • A4
    • A5
    • 3x6
    • 4x6
    • L
    • 2L
    • 5x7
    • Hagaki
    • 10x15 cm
    • 13x18 cm
    25 greeting cards,
    index cards,
    postcards, or photo
    • The print side of the cards faces up.
    • The cards are centered on the paper support, in between the left and right
    paper guides.
    • The paper guide rests against the left edge of the cards.
    • You select Normal or Photo print quality.
    25 sheets of photo
    or glossy paper
    • The glossy side of the paper faces up.
    • The paper is centered on the paper support, in between the left and right
    paper guides.
    • The paper is loaded vertically against the right side of the paper support.
    10 iron-on transfers • You follow the loading instructions on the packaging.
    • The blank side of the transfer faces up.
    • The transfer is centered on the paper support, in between the left and right
    paper guides.
    NOTE: For best results, iron-on transfers should be fed one sheet at a time.
    50 transparencies • The rough side of the transparencies faces up.
    • The transparencies are centered on the paper support, in between the left and
    right paper guides.
    NOTE: You can load a single transparency into the paper support without
    removing plain paper.
    Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
    Canon PIXMA MP130 All-In-One InkJet Printer Logo
    67 people viewed this question
    old marine
    old marine
