Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Pull Chains Replacement
My Brrokline fan has pull chains to operate the fan and the lights. 2 separate chains. One of my kids recently pulled the chain to operate the fan completely off the fan. This left it in an on position on high. How do I go about changing/reattching this chain pull so I can operate this fan?
  • Anonymous Apr 20, 2009
    pull chain for ceiling light fan how to replace
  • tchutch May 06, 2009
    pull chain completely out of housing....how to repair??
    Genius:
  • Hunter Master
  • 1,617 Answers
If that switch doesn't work call Hunter Parts @1-888-830-1326 with the model# of the fan.
Posted on Apr 08, 2015
  • 20 Answers
Replacements are available at Home Depot and Lowes. This is a regular 4-wire single-layer switch.
Mark the old wires, so you know which ports they go to in the switch (marked L, 1, 2, and 3) -- then remove the old wires by pressing a paper clip into the hole of each wire while pulling firmly on the wire. Then just push the wires into the new switch, into the marked holes.
I hope this helps! If you have any more questions, please feel free to ask!
Posted on Jun 17, 2008
  • Garrison Smith
    Garrison Smith Apr 03, 2015
    problem as NO numbers on switch being replaced. L being line and others ????
  • Jerry Hirschinger Apr 03, 2015
    Mark the wires according to the physical location on the switch body. If you get the correct replacement switch, it will have the same configuration.
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
We just recently installed a harbor breeze ceiling fan w/light and remote. During a storm the lights just quit working. What can we do?
Power outages cause ceiling fans to suffer memory loss. The basic "cure" is to disconnect fan power at the source and, while waiting a few minutes, remove the remote battery and press all buttons to verify that none are stuck. Reinstall the battery and test operation. Other factors may affect restored operation such as using wall switches and pulling the chains. The simple brain in the fan canopy can't remember switch and/or pull chain settings at the instant of power loss.
Jul 24, 2016 | Dryers
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
Fan dont run
I assume this is controlled by a wall switch.
Did someone pull one of the chains?
One of the chains turns the light on and off - and the other selects between off, lo, med and hi fan speed. Try pulling the fan chain to see if it starts.
Good luck.
Jan 26, 2013 | Home
Pull chain to turn lights on and off broke off.
Go to Home Depot or Lowes Fan Dept.  They got replacement pull chains for you.
Nov 21, 2009 | Hampton Bay 24002 Ceiling Fan
Center pull chain came out the one that turns
you need to replace the switch . which is where the chain came out
Oct 31, 2009 | Hampton Bay 52 In. Polished Brass and...
Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Feb 07, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Jun 04, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
803 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
