Question about Maytag MSD2651 HE Side by Side Refrigerator
Ice maker does not work
I replaced the water filter with a new one, just removed old one and installed new one.
I cannot get any ice to come out now, it seems the ice maker is not getting any water???
  • edbucks May 22, 2008
    The water is going to the front of the ice box. you can get a glass of water
    ok will try it, but will take some time to defrost ice box , but will let you know tomorrow if successful. --thanks ed
  • 3,037 Answers
This is a quite common occurrence. You just have an ice build up in the ice maker. Make sure the prongs are vertical in the ice maker and defrost the freezer and dry it out and you should have it working again, it not let me know and there is something else we can do.
Please let me know how this works out though
A quick fix is to take a hair dryer to the ice maker but it may freeze up right away again so its best to defrost it.
good luck
Posted on May 22, 2008
  • Benjamin Patri
    Benjamin Patri May 22, 2008
    sounds good, let me know if you have any other questions while doing this
  • Maytag Master
  • 19,396 Answers
When this happens usually you need to replace the solenoid activating the water filler
  • Ginko
    Ginko May 22, 2008
    check the duct getting to ice maker, ensure that is not obstructed or leaking.
    Check also that ice cubes does not stay stuck inside, in this case you have a problems with evaporator that release ice cube.
    If it is not the above there will be a solenoid controlling water release to the icemaker, this is probably defective.
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Ice maker not making ice, water dispenser makes a loud clicking sound when filter is in.I already replaced the dual water valve and tried a new water filter.
The gear that drives the mechanism that moves the ice out and allows fresh water to come in is damaged. In some cases the ice tray needs to come out so the ice cubes in the system can be removed by letting them actually turn back to water. Once you have cleaned it of old ice, try it again. Most likely a waste of time though.
What I have done to save money is find an old refrigerator someone wants to toss and pull the ice maker out. Chances are they have the same plug and wiring. Better if you just go get a new ice maker unit from where they sell parts for your refrigerator. It is easy to remove. usually about three screws or so. about two on top and one or more on the bottom side.
Jul 09, 2012 | Maytag MSD2652KES Stainless Steel
Ice Maker not working after replacing IceMaker and Inlet Valve. Any other ideas?
Hi. I am sorry that your ice maker is not working. Hereis a link to schedule a service call: http://bit.ly/yLv4Z5 . I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
Jun 19, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Ice maker stopped working
I just had the same problem. You need to purchase a new motor module part numnber #8021515. I purchased mine at a Sears Service Center for 77.59. I installed it yesterday and again now have ice. Took about 10 mintutes to install. The tricky little part is removing the old one. Unscrew the three screws, and there is a white tab that needs to be pressed together (use tweezers) to remove the unit from the shut off arm.
Jul 31, 2008 | KitchenAid KSCS25FKSS Side by Side...
ICE MAKER...NO WATER IN ICE PAN
do you have water thru the door? you may have air in the line. filter incorrectly installed / or a bad water valve
let me know
Apr 04, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Maytag MSD2651 HE Side by Side Refrigerator Logo
189 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
