Question about Whirlpool Kitchen Ranges
Hi I have a Whirlpool AKZ151/WH oven, it was set to 190 degrees for ten minutes then it tripped out the R.C.D I guessed it was the oven because when I switched off the red switch the trip would then re-set. I don't know what part of the oven is at fault, I get readings as follows: MOTOR COIL 105.8 OHMS OVEN ELEMENT 28.3 OHMS GRILL ELEMENT 23.3 OHMS THERMOSTAT 1.1K OHMS I'm guessing its the thermostat because I tried it cold and it worked ok. Please help Thanks Phil.
    President:
  • 1,314 Answers
Check where the cord comes in for a bad connection
Posted on May 22, 2008
Why does it take 25 minutes to preheat to around 400 degrees ?
If it's a gas range, I'd guess you have a pressure problem at the source. There should be some sort of pressure regulator at the gas tank. It might need adjusting or replacing. In other words, your oven might not be getting enough gas pressure to create a large enough flame. It should take only five or ten minutes to reach 400 degrees.
Mar 25, 2015 | Whirlpool Accubake SF362LXTS Kitchen Range
Thermador warming drawer takes 45 minutes to reach 190 degrees on high setting! That can't be right! Tech support said it should be 220 degrees on high and should take 20 minutes to fully heat.
I recommend that you go with your microwaves and claim to fix it. This can be a problem with magnetron, or power diode, capacitor faulty, or thermostat.
God bless you
Oct 27, 2013 | Thermador 30 inch Convection Warming...
On my whirlpool oven FCEM6 the display says STOP and I can not get anything to work.
hi i have a whirlpool oven type fcem6 model akz151/1x i turned the oven on and it triped the eletric and the oven would not work so i got a new element and now just the grill works but not the oven help plz
Dec 28, 2010 | Ovens
USER MANUAL FOR WHIRLPOOL OVEN AKZ151
You can fin it here
http://kitchen.manualsonline.com/ex/thread/view/idThread/2080872
Sep 22, 2009 | Ovens
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Jun 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Kitchen Ranges Logo
474 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
