Question about RCA P46812BL 46" Rear Projection Television
No Power My TV is RCA P46813BL, Chasis PTK195AA. The power would not come on. I replaced the 5a/125v fuse located by the power cord behind the rear panel. When I plug in the power cord the fuse immediately blew out. Days before the TV went out the screen had a mostly green tint to it. I left the TV off for a day or two thinking it would reset itself. When I went to turn it on there was no activity and I noticed the fuse burnt out. What could this be and what is my cost possibly in getting it repaired. watsoncedric@sbcglobal.net
I haven't tried it yet, but I will let you know when I remove the picture tube. Thank you for responding, :)
Posted on May 22, 2008
  • RCA Master
  • 8,617 Answers
Try removing the Green CRt PC voard that is on the bottom of the green Picture tube which is the center one. Then replace the fuse and see if your set powers up if it does you need a new gree tube. Just be sure the crt board doesnt touch anything while you try it. then let me know what happened, if you need a tube they arent available new any longer but I have a source for good used picture tubes,
MY RCA D52W20 TV NEEDED A REPLACMENT PLUG. I REMOVED THE WHOLE PLUG OUT OF THE BACK OF THE TV. I CAN'T FIND WHERE THE PLUG ATTACHES INSIDE OF THE TV?
the rca model itc222 chasis cord or plug runs to the front mains doubler board. this small narrow board is located in front of the large main green board. this board is a small narrow circit board behind that main board... on the right of that board there is the main fuse. next to this is the plug that the main cord plugs into
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Big Screen RCA Tv Model #P60923BL or OM60923BL
bamones, it`s possible but not likely, remove AC cord from wall outlet, remove back from set and follow the AC cord where it goes into the set, fuse is right beside where the AC cord attatches to the board, if the glass is black you have a dead short in the power supply, if it`s open but not black then try replacing the fuse, amperage is marked on the silver metal end of the fuse, look for a number followed by the letter "A". Example;
5A 125V would be a five amp fuse rated at 125 volts, DO NOT replace with any other value, good luck, BMW Rider
Dec 19, 2007 | Televison & Video
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
Fuse locations for RCA Scenium HD65W20
there are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
Mar 03, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
2 fuses blow on power up
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
284 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
