No sound nothing out of speakers. I have isolated and pre-amp circuitry is fine.
  • drummy66 May 23, 2008
    my receiver is a yamaha r2000, circa 1981
    Novelist:
    Champion:
  • 236 Answers
What brand is your amp, model.
Posted on May 22, 2008
  • Redentor Rivera May 23, 2008
    you have a defective power output transistors... you have to get it repaired by yamaha if they will still accept the model. they might tell you parts no loneger available. but parts can be found else where out of yamaha. it could cost a lot though. better consider buying a newer model.
    try
Distorted, cracked sound coming through to the speakers
is it possible your new reciever has a built in phono pre-amp?
If so, you need to switch off the pre-amp inside the turntable (lift up the rubber matt, and rotate the plate untill you see the switch at the back)
Try again now?
Feb 12, 2010 | Aiwa PX-E860 Turntable
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
Tremendous Rumble when using my new turntable
its more like your turntable needs to be isolated from surrounding interference? try putting foam or dense rubber under the feet and make sure its not anywhere near a speaker as this wil cause immense rumble problems? it may be your carridge on this new deck is way more sensitive than your previos set up and therefore needs isolation for the best results?
Apr 21, 2009 | Sony PS-LX250H Turntable
Sony preamp has no speaker output but headphone jack work fine
Hi...
If this thing is a pre-amp , it will not drive any speakers.
You'll need a power amp to connect the output of the pre-amp to...then speakers.
PLease rate my help ...Thanks
Scott
Mar 22, 2009 | Sony Audio Players & Recorders
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
No sound
then its definitely your power amp trouble in the output stage. have it checked first
May 23, 2008 | Audio Players & Recorders
Advanced multichannel power amplifier M-770
The relay sounds as if it is controlling the "mute" circuitry. If you power down the relay there is no power to the speakers. When you pull it out it is the same thing as putting it in the open position.
Just for giggles, leave relay in, before turning on, unplug your speakers, volume all the way down. Now "mute" the device. first plug the speakers in, if fuse is not blown, try adding a little volume.
With the speakers and volumke down, there is little or no current dfrawn from the amplifier section. If the device blows a fuse this time, I suspect the amplifier control voltage circuitry is bad.
If blown when attaching the speakers, susoect the amplifier circuitry.
Of dourse this does not take into account a good ol' short on the board. This would just mean that the short is AFTER the relay or there is a possibility that the relay control circuit is causing this.
There are multitude of diagnostics for a pre-amp/amp combo and either way, if your not a technician, it needs to be taken some place for proper diagnostics.
Dec 03, 2007 | Audio Players & Recorders
No right channel output
Feed the amp with the left channel preamp to the right channel input on amp and check output. If you get output from amp then pre amp nedds to be checked out if still no output then amp is suspect. Randy
Feb 16, 2007 | Bryston BP-25 Amplifier
26 people viewed this question
 Grubhead
Grubhead
