Question about PC Chips M871G Motherboard
Ram card can I use 2x1Gb DDR2 800MHz ram memory cards instead of 2x1Gb DDR 400 MHZ?
    President:
  • 2,351 Answers
Hi giovanni2,
Sorry but you're board does not support DDR2 memory.
Only 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266). There are two PC Chips M871G.
One is M871G (V1.5) & the other is M871G (V3.1). Neither support DDR2 memory. DDR2 memory used DIMM slots with 240-pin. The memory slots on you're board uses 184-pin. The board will not function with 240-pin memory.
PC Chips M871G (V1.5) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=340&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
PC Chips M871G (V3.1) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=368&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 23, 2008
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
Aug 10, 2011 | Intel D915GLVG Motherboard
Power on ok but no display. ram not detect
First disable the onboard VGA then put in a known good AGP graphics card to see if you can get through the POST if your BIOS i rejects the RAM chips it should give you a short series of beeps this would indicate that the memory is not compatible as a rule of thumb PC2700 speed memory is for a motherboard and processor with a 133Mhz FSB this is quaded to 533MHz. you can usually place faster memory but not slower memory look at the table below for rated Frontside Bus Speeds.
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200/PC2700*/PC2100 400/333*/266 MHz (min busspeed 200Mhz)
533 MHz PC2700/PC2100 333/266 MHz (min busspeed 133Mhz)
400 MHz PC2100 266 MHz (min busspeed 100Mhz)
Dec 06, 2010 | Intel KD865GRH 10 Pack (KD865GRHPAK10)...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Graphic card for GA-8IPE1000 series
HI there.
There are loads of makers of memory and graphics cards out there to choose from.
For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
These upgrades will make your machine purr like a kitten with an excellent gaming experience.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Dell Inspiron 2400 Add RAM and Vid card?
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
There u go! and YES, 2GB is tha maximum RAM you can have on that one.
But NO, you can NOT use PC3200 sticks, this is what you can use:
PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
You can read all about in the documentation obove
Good luck
Nic
Apr 09, 2009 | Dell Dimension 2400 PC Desktop
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
PC Chips M871G Motherboard Logo
138 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
