Question about HP PSC 2410 All-In-One InkJet Printer
2410 photosmart all in one
Trying to photocopy one sheet of paper - I can see the scanner trying to move from right to left (after taking the paper out) but instead of moving I can just hear a repeating clunking noise - switched off an on again several times but no change.
Phil Smith - Oxford
  • 79 Answers
unplug the power cable
Press and hold # and 6 on the printer while keeping these tow buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on. it ll perform a semiful reset on the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons on hold plug the power cable back in . when the screen goes off release the buttons and press the power button to turn the printer on .
it should fix the issue else call HP CARE and they ll replace it for u
Posted on May 27, 2008
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
Printer flashing paper jam can not locate any paper jam. I did have one but got a full sheet of paper out. The cartridges go from right to left when they get to the left side of the printer they lock up....
Perform a semi-full reset on your PSC 2410 by holding the button combination given below, while plugging in the power cord.
Press and hold # and 6 on the front panel keypad, while plugging in the power cord.
If we are talking about the cartridge jamming then
Aug 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
My HP 2410 photosmart printer has started to print everything crooked. The paper is going through perfect but the printer left margin starts to increase about half way down the page. At the bottom the...
probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
May 09, 2011 | HP PSC 2410 All-In-One InkJet Printer
HP psc 2410 photosmart all-in-one not piking up paper
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 16, 2009 | HP PSC 2410 All-In-One InkJet Printer
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
Hp 2410 xi photosmart
Possibly the scanner head trying to reset. Could be a bad sensor or drive belt. Try moving the scanner head and cleaning the area. Check the belt for any breakage.
Seems to be a common problem with this model.
Nov 14, 2008 | HP Photosmart 2410 All-In-One InkJet...
Scanner trouble
The image acuisition logic on the scanner assembly is gone bad.
It needs to be serviced / replaced.
Suggestion is to swith to Other psc or photosmart All-In-One Printer
Dec 19, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
