Question about RCA P60920BL 60" Rear Projection Television
Tv won't come on
I could hear a click, then nothing. Changed the fuse. Now when I plug in the electric chord I hear a beep, beep, beep in a rhythm (as if something were turning?) but when I unplug the beep slows until power is diminished(?)
  • RCA Master
  • 8,617 Answers
Beeping in that model usually refers to the flyback needing to be replaced or the Horizontal output transistor. Flyback is most likely the cause as the HOTransistor will usually blow a fuse causeing the set to be dead.
Posted on May 22, 2008
Won`t unlock all other doors work fine,Don`t even hear a click changed fuse still nothing.
Could be the door solenoid either plug has come off from stretched wires from opening and closing door or the solenoid has packed up altogether.Very common on a lot of cars if fuses are all good.
Apr 21, 2016 | 2008 Pontiac Torrent
The ACMP function doesnt work when I play, even tho it says it is on in the display window
Check you have selected 'sync start'. The ACMP selection activates the automatic chords but not the rhythm, so each note produces a droning chord. Sync start activates the automatic chords and rhythm you have selected when you play anywhere near the bottom end of the keyboard. Alternatively you can manually press play to start the drums by themselves and then the chords will begin the moment to play with your left hand.
Mar 12, 2015 | Yamaha PSR-E413 Portable Keyboard
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
Dec 07, 2014 | Roland RMP-5 Rhythm Coach
Have a DISNEY CARS MODEL#c1310 atv 13" TV AND WONT
possibly bad tv chord (at plug) or fuse blown inside of set..somehow you are not getting power..
Sep 05, 2014 | Televison & Video
Piano Rhythms not playing in casio ctk 7000
some rhythms have only accompaniment in it. This is not a malfunction I think. And What about this ? This is my problem with casio ctk 7000.. Can you try on the keyboard ? : Hello. I bought a Casio keyboard CTK 7000 two months ago. Firstly I did not notice the problem. But a few days ago I perceived this malfunction; Sometimes when I hit the "INTRO" button during any default (Not user) rhyhms and accompaniment plays, the playing chord is jumping to C chord. For example; When the accompanimet is playing Am chord and I push the "INTRO" button, the keyboard changes the "Am" chord to "C" chord automatically. It always happens when I hit the INTRO button at the just beginning of the measure but not at the middle of the measure. Its troublesome for me, specially during live performance. Can you help and give information about this problem? Thank you very much already now.
Nov 22, 2012 | Casio CTK-7000 61-Key Keyboard CTK7000
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Hi i have problems with my speakers on my pa 800 ,when i just play tones its clear but when i play the rhytms doesn't play right is not clear
Read your user manual about keyboard split. OFTEN the rhythms use the keys below F sharp for the chording of rhythm. When in this mode, you should restrict your melody to notes above F sharp that is to the left of middle C. If you play melody below this it will confuse the rhythm chording. You can likely change the split point of the keyboard, however, the F sharp split is the standard and I would suggest staying with it.
Dec 14, 2011 | Korg Pa800 Synthesizer
My computer does not boot
The reason with your laptop does not boot is power chord does not plug in...memory problem...operating system and corrupted hdd...
Check the power chord if properly plug to the outlet Check the memory if you heard 3 beep or 8 beep...if you hear 3 beep...the memory is not installed properly...check and install properly...if you hear 8 beep you need to replace the memory with new one...if you hear a continuous beep...the memory...discard the the laptop then off immediately...then install the memory again...
if the problem still exist...
Please go to the nearest repair center to fix the problem. Because it is very fatal and need assistance from a technician
Sep 21, 2011 | Toshiba Satellite P105-S6197 Laptop
My ps3 stopped working and i use an HDMI chord, i tried holding down the button for 10 seconds then turning it on and still nothing shows up. I checked the chord and it works. Should i plug in the red,...
I think you may be holding the power button down for too long. Instead of holding it down for 10 seconds only hold it down until you hear a second beep (it will beep once as soon as you press it). The console should stay on after the second beep and the display should initialise.
Try this method with both HDMI and AV lead (red white and yellow lead)
I hope this helps and thank you for using FixYa
Sep 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3 freezes before getting to main menu!!
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Hold the power button down; the system will turn on and turn off once again
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
When you hear the 2 beeps take finger off power button
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
198 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
