Question about Frigidaire ATF6000ES Front Load Washer
ERROR CODE 18H
When I turn on my front load atfb7000es0 it starts to beep and then comes up with the error code 18h...any idea's on what it may be?
  • 3 more comments
  • jkgwp May 22, 2008
    When I turn it on it...it locks then I hear a clicking sound. The washer then beeps 3 times and the code 18h comes up? I have tried to unplug it it does the same thing...any suggestions?
  • nenacig Apr 13, 2009
    my washer is giving me ane error 18h. it starts washing and them it stops. it wont let me do anything else. can u help?
    i have the same problem... on the screen on my frontloader i have the code 18h. it beeps for a couple of seconds...and it stops. it wont start washing. I pressed cancel and disconnected the washer already....but it wont work.........any suggestions
  • Anonymous Mar 14, 2014
    replaced door lock, cleaned out drain pump and replaced now smells like something is getting hot and does not stop spinning.
  • Anonymous Mar 31, 2014
    cannot reset machine even after disconneting power source
    President:
  • 1,314 Answers
18h is not an error code error codes will be displayed be an E followed by numbers this sounds like delayed start try hitting cancel then if that don't clear it try unplugging the unit for 5-8 seconds let me know if that don't clear it and we will run diagnostics on it
Posted on May 22, 2008
  • kidmedmary Jul 20, 2011
    Tried everything suggested= still get the 18H code
    New Friend:
  • 5 Answers
I replaced the main control... Works gr8 for me now
Posted on Dec 20, 2014
What is18h code on gltf2940es0?
Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Nov 09, 2014 | Frigidaire Washing Machines
What does error code 18h mean
Hey friend, thank you for the post!
I see you are getting an 18h code on your front load washer. Normally any error code would have the letter E or F in it. I would suggest that stands for 18 hour delay start cycle, you could do a reset on your washer by disconnecting power to it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this information is helpful. -Matt
Jul 21, 2014 | Frigidaire GLTF2940ES Front Load Washer
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
My machine gives me error code 18h wont do anything
Are you sure it is an 18h? There is no such error code for this manufacturer anywhere. What cycle was it in and what was it doing/not doing when this happened?
Sep 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
Lights come on but the washer won't start it just beeps
The beeping should accompany a error code which you can look up on this site: http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html#Duet
If there is no code check the drain for any blockage.
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Middle of cycle message comes up "err7"
Good day, FRIGIDAIRE GALLERY SERIES 4y old well mantained and clen even strainer. the electronic system suddenly went off change of cycle does not show the change of minutes an 18h shows on screen, disconect for a wile appears to work, it starts and stops after 10 minutes and beeps ready no lights then goes crazy again. Please help email: arupro@setarnet.aw
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet washer problem
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,794 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
