Question about Linksys Wireless-G WRT54G Router
How do I secure network - Linksys Wireless-G WRT54G Router
  • lady jak Sep 10, 2008
    well we have just secured our network (well tried to) we followed the instructions completely and managed to get my laptop on ok. my hubbys laptop is having non of it and is now saying that we have no i.p address! does anyone know what im ment to do? we typed in the password we created into his computer but its still not having it and now i have one not so happy hubby and of course its all my fault lol
I have make a network with wifi, now i want to secure my network so that others may not access it
Posted on Nov 07, 2008
  • 298 Answers
You can follow this steps.
1. Access the router setup page using your browser (Internet explorer or firefox), they in the address bar type http://192.168.1.1 this is the default IP address of your rotuer, if you changed it used the address that you set it to. Then you will be asked for a username and password, just leave the username blank and for password type admin (this is the default password, but if you changed it type the password that you have set on the router).
2. After doing that you will get in to the setup page of your router, At the top you click on the tab tha says wireless then under the Wireless tab click on wireless security. Just set the security mode to WPA-PSK or WPA-Personal, then in the passphrase or personal key box type the password that you want to use to secure your network (the password should be 8-63 characters alphanumeric) the click save settings at the bottom. After saving the settings your done.
3. All you need to do now is to reconnet to your wireless network and now it will ask you for the network key, and just type it and confirm it. And you will be connected again to your secured network.
If you still have any problems just reply to this post.
Posted on May 22, 2008
How do I find the WPA to set up wireless connection on my new laptop
    • 1 Right-click on your network bar in the bottom right corner and click "Open Network and Sharing Center." You can also click "Start" and type "Network and Sharing Center" in the search box. Click on the Network Sharing center link in the search results list.
    • 2 Click "Manage wireless networks" on the left-hand pane.
    • 3 Highlight the network you wish to retrieve the WPA or WPA2 security key from; right-click it and select "Properties."
    • 4 Click the "Security" tab to see the security settings. The type of security will be listed along with the encryption type and security key. The security key will be hidden.
    • 5 Check the box labeled "Show Characters." The network security key will now be visible.
Apr 12, 2012 | Zonet ZSR4154WE Router
Tip
Setting up your Wireless Printer: How to check your Network Settings
To check your network settings from your computer
  • for Vista click on start then Connect To, then right click on your network and click Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows 7 Click on the Network/Wireless icon on the task tray click on Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows XP click Start, then Connect To then Network Connections, right click on Wireless Network Connections click on Properties then write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
on Mar 28, 2011 | Office Equipment & Supplies
How do i secure my network?
In your web browser address bar type "192.168.1.1"(without the quotes)
click the "Wireless" tab on the top
click the "Wireless Security" subtab
In the selection box select "WPA Personal"
Type your desired password in the " WPA Shared Key" field
Click "Save settings"
You will now have to enter your chosen password when you join your wifi network
Mar 05, 2011 | Linksys Wireless-G Broadband Router
What is a wireless network connection network key also called a wep or wpa key. Or where can i find it?
Both are security protocol which enable the owner of an wireless network to limit the acces to that network and to protect the data that runs through that network.
WEP stands for WIRED EQUIVALENT PRIVACY and it' a security algorithm designed for wireless networks with the intention to provide a level of confidentiality close to the wired networks
WPA stands for Wi-Fi Protected Access and it's a security protocol designed to secure wireless networks
If your wireless device discovered a network that require such keys,that means that the owner of
that network secured his network,only people having acces are those who know the key.
If you have a Wi-Fi router and you forgot the key ,you have to acces the configuration page of the router ,go to wireless security page and reconfigure it, by changing the key.(get the manual of the router and follow the steps)
Feb 19, 2011 | Computers & Internet
What does it mean by network security key
The name 'network security key' is itself self-explanatory. Every network has a security key and you will need this key to be a part of that network. Just as is the case of any other term that comes from the field of network engineering, there are a lot more details attached to this term, too. So, let us try to understand all the aspects related to network security key
An explanation as to why we need a wireless network security key is not even required. Still, if any one is skeptical about adding any complexity to their available wireless network, just think about it. Your wireless network range can be detected by any other computer with a wireless setup and that comes within the range of the network. So, without you knowing, it's very easy for any user to get connected to your wireless network and gain access to all the data that you intend to share only with those computers with which you have setup your wireless network. So, what is a wireless network security key and how is it useful in such situations?
Well, a network security key or passphrase is something like a password, which any user who wants to connect to your computer will require. But, I think that before we go into the details of figuring out, how to get network security key for wireless computer, we should take a look at the different methods of securing your wireless network
Oct 03, 2010 | Computers & Internet
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
Securing wireless network
By setting up WPA2 encryption you are securing your wireless network from unauthorized access.
For details on how to further secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
What is the WEP key
Wired Equivalent Privacy (WEP)
WEP is an older network security method that's still available to support older devices, but it's no longer recommended. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. However, WEP security is relatively easy to crack. f4008eb.jpg
Nov 16, 2009 | NetGear WGR614 Wireless Router
I need to add a password to my wireless network
Do you want to secure the wireless network ?
For that you will need to access the router set up.
You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
If your network is not secured yet then you will need to make it secured and enable password protection on it.
Click Here to know more about how to make it secured
Nov 12, 2009 | Computers & Internet
I have a wireless-G Broadband Router with SpeedBooster and I need help obtaining the security code or better yet, help in setting the security to "on" because my internet company said that someone...
you will need to log in to your router.
in the wifi section select the wpa/psk security and use the serial number of the router as the security key.
you will then need to use this same number to access the router using wifi
Oct 15, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
