Question about InFocus ScreenPlay 4805 Multimedia Projector
SP4805 - Problems after Fixing Fan
The main fan broke down, which is apparantly common, and I had good luck hard-wiring it to an external DC power source - but, after putting the beast back together, I'm not getting any image. The bulb comes on, the fans work perfectly, and I've double checked my reassembly for loose wires. Everything, but no InFocus screen or image from video sources. Has anyone else had this problem? Any ideas would be helpful!
  • 563 Answers
Hi daveyboy84
Take out all the connections one by one and check the pins on the inside.
Posted on May 23, 2008
Canon ir3300 error code 000805-0002
canon ir2200 E000805-002
E805
The clock signal is absent for 5 sec or more after the fan drive signal has
been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
Main cause The fan wiring is faulty (short circuit, open circuit). The fan is faulty. The
DC controller PCB is faulty.
Action
1. Foreign matter
Is there foreign matter that prevents the rotation of the fan?
YES: Remove the foreign matter.
2. Wiring, Connector
Are the wiring and connector of the fan normal?
Developing fan (FM1): DC controller PCB (J302B)
Fixing fan (FM2): DC controller PCB (J308B)
Curl reducing fan (FM4): DC controller PCB (J311B)
Curl reducing fan (FM5): DC controller PCB (J311B)
Electrical unit fan (FM3): main controller PCB (J1028)
NO: Correct the wiring and the connection.
3. Fan, DC controller PCB
Try replacing the fan. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Nov 09, 2016 | Canon Ir 3300 Black & White Copier
Notebook 3521 is shutting down after some minutes for unknown reasons. Any suggestion about the problema?
Common problems are faulty battery, or overheating due to faulty fan. If the machine shuts down when on mains power, listen carefully for the fan. If the fan is silent or slow , you could try using a vacuum cleaner to clear any fluff out of the fan unit or get hold of a laptop cooler tray. If the unit doesn't shut down on mains power, you should get the battery checked.
Mar 02, 2015 | Dell Inspiron 15 Notebook Inspiron 3521
98 Honda CRV power/overheating
If you are loosing coolant and cant find any leaks check your oil level. If oil level is rising.you have blown a head gasket or cracked a head. Common when an engine over heats badly.
Apr 23, 2013 | Honda CR-V Cars & Trucks
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
Fan not working
the dc motor of the fan may be broke down or the wires connecting the fan
Jan 24, 2013 | I-Star (TC-400P-ATX) (TC400PATX) 400-Watt...
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
E805 ERROR OCCUR. WHAT IS THIS
Hi.
E805 is Fan Rotation Error. It means that one of the internal fans have failed. Problem is repaired accessing service mode. Identifying the defective fan through the sub-code. Reading DC voltage to fan. Replacing fan or troubleshooting supply problem.
The repair is suitable for a technician or for an expert DIYer.
Try powering down the unit (disconnect power cord), and see if this can clear the error code.
Call Canon number listed on the user manual to contact support.
Jan 09, 2011 | Canon imageRUNNER 400S Copier
I have error code e000003-0000. How do I get it working again
This is a Heater temperature error, caused by an abnormal drop, or low temperature detection.
It is most likely a blown heater element.
The main thermistor reading is lower than 140°C when paper is moved.
Main cause can be the fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). or,
The main power supply PCB is faulty. or,
The DC controller PCB is faulty.
Caution: The following steps should only be carried out by qualified people...
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
CAUTION
Do not clear the error until the fault is repaired. If you clear the error, and there is still an electrical fault it may result in a fire!
Turn on the power switch, and clear E003. (Service mode) Thereafter, turn off and then on the power switch. Does the fixing heater operate?
No? Try checking...
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
Good luck
Apr 29, 2010 | Canon imageRUNNER 2200
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
SP4805 Fan Issue
the fans in these models do not have a speed sensor wire to let the main board know to turn off the lamp to not risk overheating. so if the fan goes, the lamp remains on. however, if the lamp exploded, check the vents for dust. there is a temp sensor that will shut down the projector if it gets too hot. if the vents are clogged, blow the dust out of the projector with canned air. the dust keeps in the heat that the projector is trying to expell. easiest way to repair the fan w/o buying a part: splice the fan wires together. they can share voltage. if the 80mm fan does not work at all after that, replace the fan (pn: 526-0192-xx).
Jul 31, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
162 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
