Question about Arris WA840G 802.11g/b (49832000100) Wireless Access Point
I want to use my WAP to share my internet connection.
However, the my cable modem (Touchstone Telephony Modem by Arris) will not allow it access.
I have motorola wa849g.i reset now i want to cofigure this i open explorer put 192.168.10.1 didnot open show page canot open
Posted on Dec 13, 2008
I need the value for the network address property.
http://www.speedguide.net/routers/arris-touchstone-tm602g-voip-gateway-557
Oct 17, 2013 | Arris Touchstone Telephony Cable Modem...
I can't connect my laptop to the internet
does your laptop have wireless if not buy a wireless adapter if you use wireless. if you use Ethernet trouble shoot it if it doesent work just tell me
Aug 23, 2012 | Arris Comcast Touchstone Telephony VOIP...
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Jun 08, 2009 | Arris Touchstone 450a (CM450) Modem
I cant get out to the internet when I connect the netgear router.
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Dec 27, 2008 | Arris Touchstone 450a (CM450) Modem
How is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Jul 22, 2008 | Arris Touchstone 450a (CM450) Modem
Arris WA840G 802.11g/b (49832000100) Wireless Access Point Logo
197 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
