posted by marywilde7 on May 22, 2008
I cannot get the printer to print. I have a Lexmark2500-new! It tells me I am missing fm3032d.dll. Does Microsoft office onenote have anthing to do with this. I never had ONENOTE and now it is on my Windows Vista.
Provided by LOGITECH STAFF
Solution #1
posted on May 22, 2008
Removing the printer software and reinstalling it using a clean boot may resolve the symptoms you are
experiencing. The following instructions will walk you through this process.
b. Open the Windows Control Panel.
c. Open the Add / Remove Programs window.
d. Locate the listing for the printer software and remove it. When prompted to remove the printer drivers files, click Yes.
e. Locate any other printer software and remove it as well.
To Boot Clean in Windows Vista
Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Mantience
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
Install the downloaded printer driver/software. After performing the necessary steps, restore your system by doing the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
- Remove the printer software.
6. Click on OK
7. Click Restart.
6. Click Ok
Cheers!
IrishDruid
Comment by IrishDruid, posted on Jun 01, 2008
This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
Or post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
Thank you.
IrishDruid
Thank you.
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Lexmark X4270 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1150 All-In-One InkJet Printer
Lexmark C782N COL LASERPR 25PPM 1200DPI 256MB ETH Printer
Lexmark C780dtn Printer
Lexmark C910fn Led Printer
Lexmark C780dn Printer
Can you Help with these Printers problems?
HP LaserJet 3330 All-In-One Printer
Fax Line Programing for the...
I just switched from a... Answer This...
HP OfficeJet 300 All-In-One InkJet Printer
will not print received fax
Shows receiving fax by page,... Answer This...
Repair Service
Find Printer Repairman Near You:
