Coleman Evron CH/CA unit won't blow the air through the vents
I have a Coleman Evron CH/CA unit system outside of my mobile home. The heater works perfect, blows the air through the vents and everything but when I switched it over to the AC for the summer, it won't blow the air through the vents. It all comes on, the compressor , etc. but just no air blown through the vents.
Any ideas ?
  • deltaelise May 23, 2008
    Thanks fro your help :)
    Well it wasn't the relay. It might be the thermostat I don't know. All the fuses are good, the fan and everything comes on outside but it just won't push the air through the vents like it does when we have the heater on.
    The man I bought the relay from said to touch the green wire to the red of the thermostat wires but that didn't work either.
    I may have to wait until I get my tax rebate check to get someone to look at it and mine is in the last bunch to be sent out in July and these Oklahoma summers are hot.
    Ofcourse the man I bought the unit from is nowhere to be found and won't answer his phone or door.
    I am too poor to be ripped off.
  • keithocurry Jul 14, 2008
    I have a smiliar problem too. The air vents don't blow consistenlty throughout the house. I have a split level with one unit for both levels. The air does not come through the vents well. I can lay a miss of tissue on the vents and it won't even blow off. The house cools eventually but at a very expensive cost for me. Any suggestions?
  • 828 Answers
Relay for fan operation in the cooling mode may be bad and not bringing on the blower for the air.
Posted on May 22, 2008
I have brand new coleman mobile home furnace model # DGAH056BBSB the pilot light (elec. Start) wont stay lit and it blows COLD AIR! PLZZZ HELP Ohio is COLD
here, the last sentence is important.
http://www.ehow.com/how_5615197_light-coleman-furnace.html
Further information here.
http://handymanwire.com/ubbthreads/ubbthreads.php/topics/28213/Pilot_light_won_t_stay_lit
But if the unit is new, it must be under some sort of warranty from Coleman and from the fitter.
coleman website, support, contact and warranty, but the website doesn't list, heaters, or furnaces? I am puzzled.
http://www.coleman.com/warranty/
Oct 23, 2015 | Coleman Heating & Cooling
Need to know if my Rheem 21V30-6N water heater is approved for use in mobile home
ONLY if the air intake is located on bottom so air can be drawn from under the mobile home
http://waterheatertimer.org/How-to-install-gas-water-heater.html#manufactured
-Or- if your water heater has power vent that draws air from outside, usually through side wall.
-Or- if your water heater is installed outside.... good for warm climates only
Otherwise ordinary store-bought water gas heater draws too much air from the space, and cannot work properly in a mobile home.
Gene
Sep 30, 2014 | Water Heaters
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Colman mobile home gas furnace to use in my garage/shop
generally speaking a sealed combustion system is inherently more safe than a system that draws it's combustion air from it's ambient location. however, it cannot be considered 100% safe in a potentially hazardous location. The actual system that would be used in a "code compliant" installation would be a 100% outside air unit.
That being said, you can install this in a garage, the vent that you are referring to (if it is a standard mobile home system) is generally directly above the unit and usually no longer than about five feet. It also requires a listed and labeled termination "cap" If you install 90 degree angles or extend the vent too far you will have issues with condensation in the piping that will cause the pipe/ heat exchanger to fail prematurely.
If the system is a 90+ efficeint unit then the PVC venting is generally allowed to be about 30 feet long, with a 1/4 inch per foot pitch back to the unit for condensation, also the general mfg. instructions allow either 2- 90 degree or 4 45 degree fittings in the line. hope this helps
Nov 06, 2009 | Coleman Propane Forced Air Heater...
My home coleman ac/furnace seems to be working but no air is blowing out the vents??
If you canhere the fan running check to see if you see ice on the line going outside. If you do it is iced up . causes dirty coil,inop fan and low on gas. If unit is not ice up. Check to see if fan is running. Could be bad fan switch. also. Russ
Jul 28, 2009 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Just replace the outside unit and added knew a frame coils inside, the ac is not keeping up with the heat. my old unit was a 3 ton and worked well, my new unit is a 3-1/2 ton and working non stop, what...
start with making sure you have aclean filter, after that make sure the blower speed is at the proper setting when the air conditioning is on---usually either high or medium high for a fixed speed system, make sure the return air vents are not blocked or restricted as well as the delivery vents not close or restricted to cause too much static pressure ( back pressure at the delivery side can reduce air flow across the a-coil ) also make sure the insulation sheet that is usually above the a-coil is not being blown down across the a-coil entryside when the blower is on. After checking all these, if you find nothing you should start by having the pressure checked --- basically comparing the pressure at the "outside unit" to the pressure at the "inside unit" or a-coil. these are high side and low side pressures. Have you done anything else to the house----attic vents, new soffits, insulation, etc that may be affecting heat gain in the house.Is it a house, mobile home or what?
Jun 22, 2009 | Coleman Propane Forced Air Heater...
AC unit outside turns on but no air blows through the vents
Your indoor unit pc board is bad, replace it.
May 08, 2009 | Heating & Cooling
A/C unit not blowing enough air.
Do you change the filter regularly? And if you haven't changed it but maybe every year that is the problem. Your a-coil is plugged up and full of the stuff the filter is suppose to catch.
That is one possibility the other is and I have seen this more then once the duct work under the mobile home has come loose and is just pouring the air under there. Let me know what you find. ken
Nov 30, 2008 | Heating & Cooling
Heating & Cooling Logo
551 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
