Some buttons on tv work some dont and remote does not work
  • 8,617 Answers
Whats the model number of your set? As it may be the remote sensor or the keyboard PCB which is giving you the problem. But I will need the model number of your set in order to actually help you out with the problem.
Posted on May 22, 2008
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
I am having trouble getting my RCA Universal remote to work with my Sanyo 1080i tv... I need to change the aspect ratio...
you can do this without a remote if you have a menu button on the tv you can fix it from there. if no menu button the press the channel up and down buttons at the same time and the menu will appear. if you can not find the tv code for the remote(IF its a universal remote) then you dont need the code you just follow the steps to enter the code But dont enter a code just keep pressing the channel up button on the remote until it turns the channel on the tv when it does STOP hit the enter/ok or similar button on the remote a your remote will work like new on your tv.Hope this helps you out or atleast gives you an idea.Best of luck to you!!!! Good day
Jan 02, 2011 | Sanyo DS31520 31" TV
I have a at&t uverse remote and am trying to program it to my emerson tv,but i dont have the codes
Go to their website to find out a download copy of the codes if not just buy a new one.
Jun 29, 2010 | Televison & Video
I can't get my directv Remote to work my sanyo tv must use tv remte now to turn on tv and addjust volume
try these steps.
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code.
if your tv is not working the remote dont have your tv model stored, you need to find a compatible remote.
Feb 20, 2010 | GE JASRM24912 Remote Control
The channel up and down button is not working on my vizio remote. Is there a code I could use to reset it?
Is the power button of your remote do the same and your remote is universal? If its not your remote need the cleaning.
Aug 29, 2009 | Televison & Video
PX- rc1
Basically all it takes to restore the TV to factory setting is to unplug the TV from power and all connecting cables for about 3-5 hours (depending upon your model). This is called a Hard Reset and should restore the TV back to factory defaults.
Oct 23, 2008 | Televison & Video
Sky remote
Dear folks,
Not sure if you still need the answer but the code is 1174. I have tried it and it works -
have TV and SKY on press TV on remote
press red button and Select together until the red light on the remote flashes twice
enter the code
press the SKY button
It works!!
Aug 01, 2008 | Televison & Video
Locked tv
What is the make and model number of your flat screen tv.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
