Question about SanDisk Sansa e260 MP3 Player
Video I would like to see that video you made about fixing the one headphone problem with the Sansa. Thanks, Kelsey
  • 55 Answers
Im sorry I will try to make one on youtube ASAP i will tell you when its posted.
Posted on May 28, 2008
    Sergeant:
    Champion:
  • 281 Answers
Is it on youtube.?
Posted on May 26, 2008
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
It says key LOCKED, system shutdown. How do I fix this? It is Sandisk 4.0GB. Thanks..
There's a slide switch on the top of the machine, alongside the headphone jack. Slide it away from the headphone jack to unlock the Sansa.
Mar 05, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 headphone jack fault
There are videos on YouTube which show how to replace headphone jack on a Sansa, but they are not usually successful. May be replacement time.
Dec 31, 2008 | SanDisk Sansa e250 MP3 Player
Headphone connection
Common to all mp3 players - there are a few videos on YouTube purporting to show you how to fix the headphone jacks, but they usually don't work. Replace the mp3 player is the only solution.
Aug 22, 2008 | SanDisk Sansa m240 MP3 Player
Sansa headphone jack solution
Okay ill name it :
Dragonart18 FIX
Look For it maybe a week
May 27, 2008 | SanDisk Sansa e270 MP3 Player
Only hear out of one side of headphones with sansa player - tried 5 pairs...
i had the same problem, the headphone jack on the sansa is loose. I opened it all up, and saw that one of the connections on the headphone jack was loose. you can sauter it and it should work clearly again.
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
Hi, my sansa e250 has sound come out of only one head phone no matter how many headphones i try the same happens
The jack in the e250s is not made of adamantium, so it can actually go bad; however, if you try different headphones and thus determine that either:
  - All the headphones simultaneously went bad in one side
  - Your left ear has issues
  - The Sansa is only cranking out one channel; and
     -the jack feels a little off, or
     -perfectly good mp3s are being played off-balance; AND the balance has not been misconfigured in Settings.
...well then, the plot's moving forward and you can get your ear fixed, or stop the cat from killing your headphones, or re-load Sansa or Rockbox.org firmware, or fix the Settings, or see to the appropriate repair to the jack (depending on your warrantee status and skill with soldering irons and ordering off Jameco.com etc.)
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e140
U can try to contact the Sandisk Company at 800-426-6027 and they will have a solution for this problem
Jan 25, 2008 | SanDisk Sansa e140 MP3 Player
Headphone jack shot
did you try different headphones?
Jan 04, 2008 | SanDisk Sansa e250 MP3 Player
Headphone jack
I had to take mine apart and re-solder the headphone jack. It was amazingly easy, but if you don't do electronics repairs, I would suggest getting help. Everything is very tiny! This type of head phone jack is modular and soldered directly to the tiny internal circuit board. It is poorly anchored by the outside of the case where you plug into it, so most of the stress of pluggin and unplugging the headphones is put directly on the three tiny little solder joints. This causes one (or more) of them to break eventually. Mine lasted only about two months. And, I was carefull very gentle with it! This will cause one side or the other, or both speakers to lose their signal so that only one side works or worse, niether side works anymore. Consequently, I don't unplug mine anymore. If it breaks again, I may try to fix it. It only takes a few minutes. But, I'm hoping I don't ever get to that point.
Sep 01, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
