Question about RCA Universal Remote Control
Help me.. Hi!! I am at work and we have a tv to show clients info. and we lost the remote control codes. The remote has no code # to look for it only says RCA universal on the front...is a huge remote with red, violet and gray colored buttons any help?? thank you, wanda rios
    President:
  • 2,712 Answers
These are the codes for an RCA tv: 0047, 0019, 0051, 0018, 0038, 0090, 0135
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 22, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I have a KEVIN RM-133E remote however i lost the code of our KONKA tv can anyone help me ?
Jamir, KONKA CODES - TV 445 053 043 143 076, 103, 055, 004, 127, 016, , 044, 125, 120, 214, 215, 229, 235, 249
1034 1004, 1005, 1006, 1014, 1015, 1016, 1103, 1137, 1151
0707 0632, 0628, 0703, 1940, 0638, 1939 0037 0218 0418 0282 0587
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Remote Control Codes List TV SAT DVR
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
Remote control codes for Konka TV
4 Digit Universal Remote Codes For TV Codes For Universal Remotes
Jun 03, 2016 | Televison & Video
Lost manual need to know how to set remote to tv
You need 2 things to program your remote to your TV, the programming instructions and the correct code for your TV brand. There are 4 different methods for programming the remote, which are explained in the following videos:
Direct code search:
http://audiovox2.info/videos/rca_acc/new_intro.html
Auto code search:
http://audiovox2.info/videos/rca_acc/auto_code.html
Brand code search:
http://audiovox2.info/videos/rca_acc/brand_code.html
Manual code entry:
http://audiovox2.info/videos/rca_acc/manual_code.html
Sorry, but there is too much information to list it all here so it's much easier if you watch the videos. You will need to have Adobe Flash Player installed on your PC to view them:
http://get.adobe.com/flash/
Please note, your remote is fairly old and if you are requesting this information in order to program your remote to a NEW TV, the code searches and manual code entry are NOT guaranteed to work.
If the code searches don't work, it's unlikely that your remote can be used with your TV, but if you need to use the manual code entry method, you can find the codes for all TV brands here:
http://rcaaccessories.com/remotefinder/?sku=RCR311B&productType=TV
Regards,
BElectric
Nov 18, 2010 | RCA RCR311B Remote Control
Lost code to programme the TV with the universal remote control.
The listing I have from "hifi-remote.com" shows the code of 371 for Matsui TV's. It's the only one I found. Hope it helps you.
Oct 26, 2009 | Televison & Video
Lost remote control code I have a philip universal
Hi, here's all the codes that are registered with this specific remote control. I'm sure one of them will work for you.
002 009 020 109 122 202 209 210 222 310 322 402 408 422 508
510 807 822 901 914 917 919 922
Feb 28, 2009 | Televison & Video
Lost remote control functions
Hi, The remote lost the code and needs reprogrammed, there are 8 code choices for a sanyo tv. Manually turn on the tv. On the remote, press the code search key till it lights, press the tv key, it will blink then stay lit. Aim the remote at the tv, keep it pointed at the tv and press the on/off key ONCE. When the tv turns off press enter. If you wait more than 3 seconds it will scan to the next code. So if you try it the first time and not all of the functions work correctly is when you would let it scan to the next one. Good Luck! Please rate my response.
Feb 08, 2009 | RCA RCR412B Remote Control
Hi i have a giant tv remote lost the code for the rca tv the remote is an Omni tech could you help
yes i can... the codes are 000,003,004,005,007,009,011,015,048,082,092,094,096,098,101,102,103,107,113,125,129,167,179,187,188,191,and 194. ok you first turn on the tv. then hold down on the code search button for 3 sec. or untill the led stays on. try each 3 digit code untill it works. some codes my turn off tv but wont change channels. try another code untill it all works for you....... hope this helps........ thanks eddy
Jan 02, 2009 | Brookstone 538744 Remote Control
Ive lost my code book to my tv remote. so i havent had tv for a couple of days lol. the remote mak is Total Control URC-11-2840 and my tv is a sony i need the 4 digit code can you please help. much...
Sony 4 Digital Codes 0000 this is the only code showing in my book for sony RCA uses 000 for theres You can go to dollar store buy remote handunit for 5.00 with codes to TVs.
Jan 02, 2009 | Televison & Video
Lost code book
i lost my book of codes for protron t.v i need a code
thaks for your info :)
Dec 12, 2008 | Universal Remote Control Hampton Bay...
Hi my name ghanshyam patel i buy one 8-in one remote px-rc1 in xs cargo. i lost cod list book . my tv brand name is sanyo. pl u help me find the code of this remote to my tv thanking u
http://tv.manualsonline.com/manuals.Go to this site and enter your info and download your manual giving all info on codes and how to program.RICHARDM69
Dec 07, 2008 | Philips Magnavox Learning Universal Remote
Lost my code book for rca univ remote
Well I know this is a few months late but go to www.rca.com/codefinder to find the codebook. Usually the model number of your remote control is on the inside of the back lid. Just take it off and flip it over.
May 22, 2008 | RCA Universal Remote Control
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
