Question about Mitsubishi WS-65807 65" Rear Projection Television
Problem with shutting down
Hi there I am having a problem with the unit power off after 30min to an hour. after words with wont come on for hours. unit has no other problems then that. there is a sticky gum like substands between a couple of caps in the back on a board is that normal? . . Thanks for any help.
  • Mitsubishi Master
  • 8,617 Answers
No. The stickt resisdule is either the capacitors leaking or fluid leakinf from the CRT (picture Tube) IF it is just a small amount that is centerd only near those capacitors its most likely the caps and they will need to be replaced. But look good to see if there is evidence of a larger area of leakage its probably the crt leaking. Either way the caps will need replacement and if the CRT is leaking the seal may need to be replaced or toghtened on the CRT. let me know if you need further assistance
Posted on May 22, 2008
MY SHREDDER IS OVERHEATING
Significantly Improve the Manufacturer's Suggested Duty Cycle, from Intermittent Use: ON=6min / OFF=30min to CONTINUOUS USE
ROYAL PX1201
My comments below are addressing these 3 issues:
1 How to permanently fix the motor overheating
2 How prevent motor thermal shut-down
3 How considerably improve the duty cycle
I am sharing this info with you with the hope it may save you some time.
Did purchase this unit from Costco about 6 years ago, in 2010.
This unit is functioning well today except its motor was overhearing and going into automatic thermal shut-down.
The ROYAL PX1201 model # is PCUA: 29127H-FE ; the Lot # 111155925.
Had to open the motor enclosure quite few times for cleanup and cooling.
Note the manufacturer's recommended duty cycle is ON=6min / OFF=30min. Nobody I know has 30min time to babysit a shredder.
In thermal shut-down mode the motor would not turn in any direction.
Today I modified the ROYAL PX1201 by adding an external 12V DC computer fan for motor cooling.
Cut a fan-placement, round, 3.25inch hole into the shredder top, at the upper right of the paper-insert slit: ____O
External, room-air is being forced into the motor-and-gear enclosure at all times, non-stop.
The paper-insert slit provides the hot-air exhaust.
The fan is an ordinary plastic PC fan: 12V DC, 0.12A=120mA, XYZ=72*72*20mm ; diagonal=101mm (hole-to-hole).
Fan cost is around $5.- and the fan power supply was a separate 12V DC adapter.
Did not have time to electrically connect the fan to the shredder's internal power supply.
Today I used the shredder continuously for 8 hours with neither overheating nor thermal shutdown.
Did fill TEN 13-gallon plastic bags with shredded paper / hand compacted confetti.
On average I shredded 6 letter-size, normal thickness pages at a time / per feed, continuous feed for about 8 hours.
Jan 09, 2014 | Royal Office Equipment & Supplies
Old Gateway system (Desktop), Celeron 800MHz. After being on for 30min to an hour, operating system quits. Monitor displays first "no input" then "power saving" and will indefinitely keep cycling between...
sounds like its an over heating issue,i would check the fans to make sure they are all working and clean.Check that the cpu has thermal paste and that it still good(if its stiff or crumbles when you take off the heatsink it needs to be replaced)also check the memory is seatted all the way in.
Sep 01, 2010 | Gateway (683728192730) Barebone
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Jan 20, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I bought an LG HDD/DVD Recorder a few month ago, it worked well. But recently, it cannot start. Previously, after put on the power, a message showed: "Preparing, Please wait", and after a while,...
HI,
Please do a reset by unpluging all the cords of the player for 30min.After 30min. plug all the cords in and let me know if you still get the same error.
Nov 30, 2008 | LG Televison & Video
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Sanyo plv z4 shuts down
call sanyo tech department and they will help you increase the fan speed to cool the unit. This is done with the remote so it was pretty easy. Make sure your filters are very clean first (use compressed air or a co2 canister. Have not had a problem since, my units run on average 8 hours a night and have not shut down.
Nov 09, 2007 | Sanyo PLV-Z4 Multimedia Projectors
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
