Question about Philips Televison & Video
We lost electricity for about 30 minutes but then we turned on the tv and we cant see the images....we can hear it but cant see ....we cant even see the menu.....help
  • Philips Master
  • 8,617 Answers
I will need the model number of your TV in order to help you diagnose what the problem may be.
Posted on May 22, 2008
I have a 55" Sony Rear Projection TV and when I turn on he TV I hear the voices but it takes the picture about 30 minutes to come on? The bulb was replaced less than years ago
First is the model listed here does not use a bulb, it has 3 picture tubes. What is actual model number as I think wrong one is listed here.
Dec 20, 2012 | Sony KP-51HW40 51" Rear Projection...
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
My 56 Gateway rearprojection tv takes about 10 minutes to turn on. When you hit the power button I can hear a loud humming sound and in about 10-15 minutes the tv turns on. After watching tv for about 30...
take to a shop for 29,95 to check. vise 150.00 to check in home. call around some charge more. Its better to know , than guess on that kind a money. age is a factier in repairs.
Jan 03, 2018 | Gateway DLP56TV 56" Rear Projection...
The tv is slow to turn 20 -30 minutes
The tv Tuner board is dead.Need the Tuner replacement,that the board,where the air incomming brocasting signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Aug 03, 2010 | Toshiba 26LV47 26 in. LCD TV/DVD Combo
Image lost after 5 min turning on the tv, sound was ok.
I would suspect overheating of an electric component in the power supply of the lamp (backlight) of your lcd tv. bring it in for repairs.
Nov 29, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Sound but no picture
I had the same thing happen, replaced the backlight inverter and it works fine. I got mine from http://www.lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=V144-001MSS.
Nov 25, 2007 | HP LC3040N 30 in. HD-Ready LCD Television
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
